how much timing should I pull for a 100 shot?
Old Dec 22, 2006 | 09:29 AM
thehatchninja's Avatar
Default how much timing should I pull for a 100 shot?
I don't want to sacrifice nice all motor power, and I definitely don't want to melt a piston or something. So I'm going to use this
That way at the flip of a switch I can run a safe nitrous program. BTW this is going to be a single wet shot.
My setup
GSR mota
-Eagle Rods
-JE 11.5 pistons
-ARP head studs
-head milled .030
-Sk2 stage 2 cams
-440cc inj
- 255LPH fuel pump
My main question is....Is it possible to run the same plugs and base timing and just use ECU tuning to adjust for the nitrous?
Modified by thehatchninja at 4:32 PM 12/22/2006
Old Dec 22, 2006 | 02:07 PM
Forrest Gump 9's Avatar
Default Re: how much timing should I pull for a 100 shot? (thehatchninja)
2 degree it the reccomendation, but 2 more for safety. So a total of 4 degree. If you have Hondata, you can set it up so it's only pull timing when you on nitrous.
Old Dec 22, 2006 | 05:41 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: how much timing should I pull for a 100 shot? (Turbo9Nut)
I recc 4-6 degrees on 11.5 cr and yes with hondata or crome you can set it up where it will pull timing as soon as you hit the button (crome 2 timer, 2 seperate programs that will switch over when you press the button)
Old Dec 22, 2006 | 06:44 PM
98vtec's Avatar
moderator emeritus
Default Re: how much timing should I pull for a 100 shot? (WHITFIELD-TUNED)
moates *
Old Dec 22, 2006 | 08:53 PM
DYNO-PRO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to sacrifice nice all motor power, and I definitely don't want to melt a piston or something. So I'm going to use this
My setup
GSR mota
-Eagle Rods
-JE 11.5 pistons
-ARP head studs
-head milled .030
-Sk2 stage 2 cams
-440cc inj
- 255LPH fuel pump
Modified by thehatchninja at 4:32 PM 12/22/2006</TD></TR></TABLE>
yes this can also be used for a burnout limiter .... example on the 2 timer you cave to exact same tunes... one with a rev limit of like lets say 6000rpm... so you have a momentary push button on the steering wheel and when it is pressed you are running the tune that has the 6k revlimit .... burn out bouncing off the limiter and then release the button and you are back on the original tune with you vss activated launch control.... fun fun fun .. this setup can also be used to build alot of boost off the line (retarded timing and alot of fuel) and right after the launch you let of the button and you are back on the reg. tune
Old Dec 24, 2006 | 09:58 AM
that's awesome!
I will have to get one....or are you saying with Crome I don't need one of those, just a standard chipped ECU?
Old Dec 25, 2006 | 08:15 AM
nitrous ftw.
R3PT4R
Nov 17, 2010 05:41 PM
Tippyman
Nov 22, 2005 09:11 PM
93b16delsol
Aug 9, 2005 01:29 PM
JDM JEFFREY
Dec 24, 2004 08:42 PM
B18C1CYA
Jul 28, 2004 11:53 AM
