D-Series Transmission Rebuilding / Interchangeabilty of parts
Old Dec 21, 2006 | 08:24 PM
lvlrlvlopar's Avatar
Default D-Series Transmission Rebuilding / Interchangeabilty of parts
I have a 90 civic with a broken Si trans. I want to rebuild it. I heard that hydro trans have stronger shift forks is that true and if so can i swap them into my cable trans what other rebuild tips can you recomend for extremely hard shifting? IE: ALOT of no-lift shifting. Would a light weight flywheel be easier onthe syncros? does anyone make carbon coated syncros or 2 piece syncros for a D-series?
Old Dec 22, 2006 | 08:20 AM
Jim Truett's Avatar
Default Re: D-Series Transmission Rebuilding / Interchangeabilty of parts (lvlrlvlopar)
Some hydro parts are interchangeable, but not the forks. Don't abuse it and you won't break the aluminum forks anyway. The light flywheel will have no affect the synchros because you are disconnected from it when you shift. The carbon synchros can be purchased from http://www.gearspeedinc.com/
Old Dec 22, 2006 | 02:43 PM
Bense's Avatar
If you want, you could order a DOHC ZC trans from hmotors. And use your differential + final drive + 5th gear in it.
the dohc zc cable trans has all the same bearings, forks, synchros, etc as your 90 si trans. That way you'd have an extra pool of spare parts + good gearing.
Old Dec 22, 2006 | 06:54 PM
quicksilver1689's Avatar
i ♥ snails
Bense is my hero
Old Dec 23, 2006 | 01:39 PM
well guess what tonight driving home from my cousins i decide to rip on it a little bit 1st 2nd go for third wont go in try 4th wont go 5th wont go. "ohh ****" let out the clutch slowly, its stuck in 2nd gear. not the first time this has happened its gettign old prety quick this trans only lasted me 2 and a half months maybe im a little hard on em does anyone know of a place that makes like chromoly shift forks or something so i dont have to keep swapping transes every 3 months
Modified by lvlrlvlopar at 7:24 PM 12/23/2006
Old Dec 23, 2006 | 02:06 PM
Bense's Avatar
don't powershift.
Old Dec 23, 2006 | 10:16 PM
thats not going to help because im not gonna stop beating on it. i want to make it stronger so it wont break again
Old Dec 23, 2006 | 10:40 PM
Bense's Avatar
whatever dude, what do i know. Good luck
Old Dec 23, 2006 | 10:56 PM
im not tryin to be an ******* here i just love nolifting my car i want something that will hold up to it. anybody ever heard of putting a b series trany behind a d series becasue as of now i have an extra one sittin in my garage
Old Dec 24, 2006 | 10:04 PM
Jim Truett's Avatar
Default Re: (lvlrlvlopar)
What do you think that will do for you? They are the same basic design. Change your driving habits or get used to swapping transmissions.
Old Dec 24, 2006 | 10:32 PM
91SiZ6's Avatar
Word. You can't expect to missuse something and get reliability out of it.
Old Dec 25, 2006 | 06:17 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: D-Series Transmission Rebuilding / Interchangeabilty of parts (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">Some hydro parts are interchangeable, but not the forks. </TD></TR></TABLE>
Sorry Jim, but 5th gear shift fork interchangeable (same PL3 part)....
Yet to try the P20 1-2 fork, it is beefier.
No lift shifts are not a problem, agressive driver who can't shift is.
Old Dec 25, 2006 | 01:44 PM
those carbon coated syncros should help though shouldnt they?
Old Dec 25, 2006 | 03:54 PM
Jim Truett's Avatar
Default Re: D-Series Transmission Rebuilding / Interchangeabilty of parts (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
No lift shifts are not a problem, agressive driver who can't shift is.</TD></TR></TABLE>
That I know, but to keep it simple for the OP I omitted that info. He was looking for stronger parts, and that would not help him in his quest. I took it from the angle of the steel '96+ forks not being compatible with his case.
The P20 1-2 fork should work with a modified sleeve. I have been too lazy to try it myself. I haven't broken a PL3 one yet anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvlrlvlopar &raquo;</TD></TR><TR><TD CLASS="quote">those carbon coated syncros should help though shouldnt they?</TD></TR></TABLE>
Not if your shifting style does not allow for smooth, timely engagement.
Old Dec 25, 2006 | 08:36 PM
so whats wrong with my style? i ran a 15.2 at 90.55 with a 2.2 60ft in a 90std d16z6 converted to obd1 with a "homade" exhaust the car dynoed 95 hp on dynapacks before the exhaust not saying that its the fastest car in the world no am i the best driver but thats better than i was expecting for my first time ever at the track on my 2nd of 2 runs. is there a tutorial on H-T somewhere how to correctly powershit a civic?
Old Dec 25, 2006 | 08:49 PM
is the p20 fork that much stronger i thought they were alumnium too. honastly im willing to try prety much anything except my abusive trany habbits, i dont mean to be a stuborn *** but it gives me pleasure to rip through the gears
Old Dec 26, 2006 | 05:13 AM
Mista Bone's Avatar
D Tranny Guru
then learn to drive......you'll stop breaking forks......and learn to shift quicker....
Old Dec 26, 2006 | 08:52 AM
thehatchninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvlrlvlopar &raquo;</TD></TR><TR><TD CLASS="quote">so whats wrong with my style? i ran a 15.2 at 90.55 with a 2.2 60ft in a 90std d16z6 converted to obd1 with a "homade" exhaust the car dynoed 95 hp on dynapacks before the exhaust not saying that its the fastest car in the world no am i the best driver but thats better than i was expecting for my first time ever at the track on my 2nd of 2 runs. is there a tutorial on H-T somewhere how to correctly powershit a civic?</TD></TR></TABLE>
you didn't run a 15.2 by beating the crap out of your tranny. You did it b/c you have a decent motor in a lightweight chassis. Look for a road race tutorial they talk about shifting smoothly and quickly.
Basically, if I remember correctly, don't grab the shift **** with your fist, rest your palm on top of the shift **** and use your fingers for 1&gt;2 and 3&gt;4 shifts and the heel of your palm for the 2&gt;3 4&gt;5 shifts. Hopefully that makes sense...i always kind of hold it with my thumb too. Also always make sure the clutch is fully disengaged.
Old Dec 26, 2006 | 12:23 PM
what a coincidence that exactly how i shift
Old Dec 26, 2006 | 01:32 PM
Bense's Avatar
The first step is admitting that you have a problem.
sucks for you.
Old Dec 26, 2006 | 02:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvlrlvlopar &raquo;</TD></TR><TR><TD CLASS="quote">what a coincidence that exactly how i shift </TD></TR></TABLE>
Also don't try to shift too fast.....let the syncros do their job.
There is also a SMALL chance that the 15 year old transmissions that you're buying are already messed up and you just push them over the edge. If that's the case then rebuilding it to stock specs would be fine......maybe use the carbon syncros, and cryo'd shift forks.
Old Dec 26, 2006 | 04:42 PM
91SiZ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurnFast.com &raquo;</TD></TR><TR><TD CLASS="quote">The second bad habit some people have is shifting with excessive force. Too tight a grip, and slamming from one gear to another will actually slow your shifting down, and cause excessive mechanical wear. Proper shifting uses an open palm grip on the top of the shift ****, and a gentle but fast guide from one gear to another. We repeat---all shifting is properly done with the hand open and cupped over the top of the ****, not wrapped around it like a fighter plane control stick.
Some of you may be tempted to learn the techniques of "speed shifting"--shifting without using the clutch--in the interest of saving time. Many schools and professional racers have shown over and over that there is no speed or lap time advantage to this, and it carries a much higher risk of gear box damage.</TD></TR></TABLE>
http://turnfast.com/tech_drivi...shtml
Old Dec 26, 2006 | 07:49 PM
thanks guys i guess i am going to rebuild it back to factory specs and ust the carbon syncros see how that works. but in the mean time i still need a trany does anyone have a cable d series in the upstate ny area that they want to sell cheep
Old Dec 26, 2006 | 10:37 PM
mugenEGG's Avatar
cant you use LS rods in a d16z6?
Old Dec 26, 2006 | 10:49 PM
Default Re: (mugenEGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenEGG &raquo;</TD></TR><TR><TD CLASS="quote">cant you use LS rods in a d16z6?</TD></TR></TABLE>
yes....but that has nothing to do with transmissions
rstchris
Transmission & Drivetrain
Jan 29, 2012 04:09 PM
civicflow
Aug 9, 2010 03:46 PM
anrkii
Jun 12, 2008 03:08 PM
spun Vtec
Mar 17, 2008 02:05 PM
NVMYSi
Feb 29, 2004 03:16 PM
