headlight bulb out
Old Dec 21, 2006 | 07:47 PM
garrettej8's Avatar
B A N N E D
Default headlight bulb out
I currently have PIAA super plasma gt-x H4 bulbs and I've had them for about 8 months now. All of a sudden my passenger side bulb doesn't work but it does when the high beams are on. I checked the plug and it had a little corrosion, but not enough in my opinion for it not to work. Does anyone know what's up?
Old Dec 21, 2006 | 08:19 PM
b16adx's Avatar
Default Re: headlight bulb out (garrettej8)
come on dude....are you serious
Old Dec 21, 2006 | 10:18 PM
garrettej8's Avatar
B A N N E D
well I'm asking so yes, I guess I am serious.
Old Dec 21, 2006 | 10:25 PM
jdmek9imagex's Avatar
Default Re: (garrettej8)
replace the damn bulb and you should be fine, there nothing else you can do. its an h4 bulb, so the lowbeam when out on you.
Old Dec 21, 2006 | 10:37 PM
MidwestSiR's Avatar
Default Re: (jdmek9imagex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek9imagex &raquo;</TD></TR><TR><TD CLASS="quote">replace the damn bulb and you should be fine, there nothing else you can do. its an h4 bulb, so the lowbeam when out on you. </TD></TR></TABLE>
basically
Old Dec 22, 2006 | 01:30 AM
ahhsimon's Avatar
piaa sucks over priced bulbs
Old Dec 22, 2006 | 06:10 AM
Padawan's Avatar
Darth ModerVader
Here's the procedure:
A. Swap the faulty bulb to the driver's side. If it works fine, then it's a wiring/electrical issue. If it still doesn't work, see B.
B. Replace the bulbs with a high-quality set such as Philips Vision Plus or <u>Osram</u> (not Sylvania) SilverStar.
Old Dec 22, 2006 | 07:24 AM
miahmouse's Avatar
Default Re: headlight bulb out (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Here's the procedure:
B. Replace the bulbs with a high-quality set such as Philips Vision Plus or <u>Osram</u> (not Sylvania) SilverStar. </TD></TR></TABLE>
I wouldn't even bother with A though... don't think I've ever seen a set of PIAAs work for more than a year...
Old Dec 22, 2006 | 07:28 AM
Padawan's Avatar
Darth ModerVader
Default Re: headlight bulb out (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't even bother with A though... don't think I've ever seen a set of PIAAs work for more than a year...</TD></TR></TABLE>
The reason I mentioned it was because he stated that the connector had corrosion on it, which could be preventing contact with the low-beam positive lead. In all likelihood though, it's simply a dead bulb.
Old Dec 22, 2006 | 08:01 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The reason I mentioned it was because he stated that the connector had corrosion on it, which could be preventing contact with the low-beam positive lead. In all likelihood though, it's simply a dead bulb. </TD></TR></TABLE>
good call
one Q though... What's the difference between OSRAM and Sylvania.... thought they were the same company?
Old Dec 22, 2006 | 08:12 AM
Padawan's Avatar
Darth ModerVader
"OSRAM SYLVANIA is the North American operation of OSRAM GmbH, Germany, one of the world's leading lighting manufacturers, and a member of the Siemens international family of companies.
With regard to the bulbs, the Sylvania SilverStar is the one that is commonly available at auto parts stores in North America. It has a coating that is intended to produce a "whiter" light output. The superior bulb is the European Osram SilverStar, which has no coating. It is not offered for sale in North America, and must be ordered from a European bulb supplier (which is simple and inexpensive).
Old Dec 22, 2006 | 08:51 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">"OSRAM SYLVANIA is the North American operation of OSRAM GmbH, Germany, one of the world's leading lighting manufacturers, and a member of the Siemens international family of companies.
With regard to the bulbs, the Sylvania SilverStar is the one that is commonly available at auto parts stores in North America. It has a coating that is intended to produce a "whiter" light output. The superior bulb is the European Osram SilverStar, which has no coating. It is not offered for sale in North America, and must be ordered from a European bulb supplier (which is simple and inexpensive). </TD></TR></TABLE>
Happen to have a link?
Old Dec 22, 2006 | 08:56 AM
Padawan's Avatar
Darth ModerVader
The Osrams are available from http://www.powerbulbs.co.uk
In a recent test of H4 "+50" bulbs, the Philips Vision Plus was found to perform better. That bulb, as well as the newest Philips X-treme Power can be ordered from http://autolamps-online.com. Autolamps is the company I dealt with when I ordered my Vision Plus bulbs. Ordering is easy, and shipping is free and quite quick.
Old Dec 22, 2006 | 09:06 AM
miahmouse's Avatar
thanks man
Old Dec 22, 2006 | 09:24 AM
garrettej8's Avatar
B A N N E D
Thanks for the info guys
I'm going to try the bulb in the other headlight and see if it truly is burnt out or the plug is just corroded too much. If it doesn't work then I'll just throw my factory bulbs in and order some of those osrams which seem to be pretty good.
jasony0630
12
Apr 11, 2008 09:44 AM
93h22hatch
Jul 21, 2006 03:22 PM
asgqwaeg
May 5, 2006 05:32 PM
Da1Gsr
Mar 6, 2006 07:03 PM
Intercooler
19
Jan 5, 2006 12:14 PM
