PROBLEMO!
Old Dec 21, 2006 | 05:52 PM
nemo_4321's Avatar
Default PROBLEMO!
I have a problem with my 1988 CRX HF. I tried searching and couldn't find anything. I went to pull the car out of my garage and i wouldn't go. I put it in 1st gear and let of the clutch and it would take off at all. I tried all 5 gears and none would work. Even reverse would not work. I am thinking that it is the clutch. Also im thinking of getting a 88 SI tranny. Should I do that? Thanx
Old Dec 21, 2006 | 05:55 PM
omgwtfbbqcrx's Avatar
Default Re: PROBLEMO! (nemo_4321)
sounds like the clutch to me, if yours is a 4 speed i would recommend getting the si tranny unless you are concerned about gas mileage, you will probably have to replace the clutch on the si tranny too
Old Dec 21, 2006 | 06:37 PM
JOE BD-0's Avatar
This sounds stupid, and it probably is, but check your shift linkage roll pin, or "BITCH" pin as they call it on H-T, 'cause you never know....Believe me....it happens...good luck
frazz
Jul 29, 2014 06:40 PM
supereg2
Mar 21, 2008 09:51 AM
Blueallie
Jan 27, 2005 06:04 AM
J-Brooks
Dec 17, 2002 10:23 AM
civic_sir94
Nov 27, 2001 05:45 AM
