tranny, clutch, wha?
alright, my friend just bought a 93 SI, an when he put it into reverse it would grind sometimes for no reason, so then one day hes driving an its in 3rd an he cant get it out of third, finally he mashes the clutch, an get its to neautral, but now he cant get it into gear AT ALL, so i was wondering if any of u had any idea of what coulda happened, he had to get an oil leak fixed so they had to take out his clutch an bla bla, but i dont think the problem is with the clutch? thanks
New User
Re: tranny, clutch, wha? (cIvIc_gSr95)
I would say tranny. I had a 92 SI. It started grinding gears, then one day it got stuck in 2nd. I drove it to a tranny shop, they couldn't get it out, on the way home I suddenly was able to shift again, but I wasn't able to get it into reverse. A couple weeks later I lost 2nd gear. I replaced the tranny and clutch and the problem was solved. The Complete drivetrain is now in my friends civic and he has just lost 2nd gear again, so I think it is the tranny because the clutch only has 10,000 on it. You should be able to pick up a tranny for like 300
That's just what I think, I could be wrong.
D Tranny Guru
quite a few things.......
air in clutch hyd. line, hub spring popped out, low oil level in tranny, are just a fews thoughts.
