GM Synchromesh with Chrysler Friction Modifier
Old Dec 21, 2006 | 05:39 PM
sexyrex's Avatar
Default GM Synchromesh with Chrysler Friction Modifier
awhile back i owned a Dodge Ram Pickup, and i also did a transmission drain & fill and remember using a friction modifier. It came in a tiny bottle.
i have been reading around the internet and found out, it's the same additive used in the GM synchromesh.
"Both automakers also use the NV1500 manual transmission, which also requires the Synchromesh fluid. However, the NV1500 transmission requires additional friction modifier to achieve proper performance and protection. General Motors part No.12377916 already has the friction modifier added. On the other hand, Dodge applications using the NV1500 require Chrysler part No.4874464, which does not have the additional friction modifier added. Therefore, an additional 0.2 pint (0.1 liter) of friction modifier must be added to Chrysler part No. 4874464. The friction modifier may be purchased at your local Dodge dealer"
found at
http://www.turbodieselregister....html
gm synchromesh with friction modifier is pretty hard to find without waiting a few weeks, so that is why i am inquiring about this additive
has anyone tried this? any input would be appreciated, thx.
Old Dec 22, 2006 | 06:36 AM
SOHFAST94's Avatar
Default Re: GM Synchromesh with Chrysler Friction Modifier (sexyrex)
True but, through independant testing I've found the Royal purple sycnro max although does not have this vertain friction modifier supposedly does work better when mixed with a little Racing 21.
Old Dec 22, 2006 | 10:12 PM
sexyrex's Avatar
hmmm would you think mixing the chrysler friction modifier to any kind of mtf would work just like the gm stuff?
Old Jan 3, 2007 | 07:56 AM
SOHFAST94's Avatar
Default Re: (sexyrex)
I've honestly found that if you use a little it works well. IMO I think that the GM sychromesh is little on the thin side so I normally mix it with a little something extra.
SacrificeTheory
Transmission & Drivetrain
Oct 18, 2009 05:50 PM
sdr85
Sep 24, 2007 12:39 AM
vicious_1132
Jun 7, 2004 09:53 AM
rtiadnoh
Apr 22, 2004 10:10 AM
made in JAPAN
Mar 6, 2003 11:04 AM
