HT help?
Old Dec 21, 2006 | 03:47 PM
95civhb's Avatar
Default A couple questions..
I posted this up in hybrid.. but I need to get a solid answer on this soon and they're not coming quick there..
I'm looking at doing a b18b1 (OBD1) swap into my EG.. (no jumper harness required..)
I looked at the gsr writeups (e.g.
http://forums.evans-tuning.com...light)
looks like direct bolt... some writeups had that you need a mount from an integra ..
fact or fiction??
are stock axles are ok for the time being??
Here's what I have compiled as a list of what I need..
Engine
Tranny
ECU
shift linkage
anything more that I'll need??
I'm probably going to replace my mounts if I do the swap... should I get mounts for a teg, or will the EG mounts suffice?? I'm just goin the OEM route with the mounts..
I know a lot of questions.. all help is appreciated!
Modified by 95civhb at 5:30 PM 12/21/2006
Modified by 95civhb at 5:31 PM 12/21/2006
Old Dec 21, 2006 | 05:19 PM
BlueIntegraBoy's Avatar
Default Re: A couple questions.. (95civhb)
Stock Integra axles will work, yes.
Search is working real slow for me, otherwise I'd post a pic of the mounts you need. You can use stock upper tranny mount, two front torque mounts, and the crossmember mount. From the Integra, you need the lower front tranny bracket, rear tranny bracket, AC bracket, and driver side mount.
Are you using the B1 harness?
90lsvcrxva
Feb 13, 2012 01:12 PM
ivan93egreppin210
Dec 14, 2008 04:27 PM
95civhb
Dec 28, 2006 04:23 PM
Boosted B6teen
Dec 7, 2005 07:41 PM
sleep
Aug 8, 2005 05:36 PM
