Stripped Ball Joint Stud?
Old Dec 21, 2006 | 01:41 PM
Ltsmith05's Avatar
Default Stripped Ball Joint Stud?
So I was trying to torque down the castle nut, and then it just started spinning and spinning. Now the thing just keeps spinning and spinning, and won't go up or down either. The castle nut is as far up the stud as I'd expected it to go and the cotter pin is in, but I just can't torque the damn thing down. Is this normal? Is the stud stripped? If so, do I need to do all of the work I just did over?
Old Dec 21, 2006 | 01:50 PM
e jay one's Avatar
Default Re: Stripped Ball Joint Stud? (Ltsmith05)
probably the balljoint is spinning my rex has the same **** i just stuk the cotter pin in and called it a day.
Old Dec 21, 2006 | 02:13 PM
Slamaccord's Avatar
Default Re: Stripped Ball Joint Stud? (e jay one)
PLEASE DON'T DO THAT!!! ^^^
Try by jacking up the car from the lower control arm.
Resting the weight of the car on the lower ball joint might work.
Old Dec 21, 2006 | 02:30 PM
Ltsmith05's Avatar
Yeah, I just jacked up everything from the LCA and it wasn't tightening any more. The thing that is just worrying me about it is that it isn't coming off either. I am also definitely seeing some metal shavings coming through the castle nut.
Old Dec 21, 2006 | 02:40 PM
7PSI CRX's Avatar
Default Re: (Ltsmith05)
Impact Gun.
Old Dec 21, 2006 | 03:09 PM
EG8R's Avatar
Default Re: (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Impact Gun.</TD></TR></TABLE>
Old Dec 21, 2006 | 03:12 PM
Ltsmith05's Avatar
I'm not worried about getting it off right now too bad. I'm just worried about my saftey and whether the car is going to get fucked up if this thing isn't tightened down. I'll worry about getting it off when I need to the next time. So please just keep it to comments on the actual problem or a fix (harsh, but I just need to get this figured out).
Old Dec 21, 2006 | 03:29 PM
gospeedgo1's Avatar
i had the same problem. get some vise grips and lock them in place. use that to put the pressure on the balljoint while you tighten or loosen it.
Old Dec 21, 2006 | 06:52 PM
Ltsmith05's Avatar
Tomorrow I'm going to drop it down and let it sit on the wheel with a full load for a bit and then see if I can't get the damn thing tight. If that doesn't work I'm going the vice grips/c-clamp route. If those both fail I might try and get a hold of an impact and try to cram the damn thing on. The last resort will be to just go buy another new ball joint at the local auto parts store and run the car to the closest mechanic and have him press the thing in for me. Why does working on cars have to be such a PITA?
Old Dec 21, 2006 | 06:58 PM
gsxr1k05's Avatar
ltsmith05, i had the same problem, and i tried the jack routine, and the stand on it ****.. impact gun is what got it for me.. get one and call it a day.. and electric will work as well as an air.
Old Dec 21, 2006 | 08:58 PM
e jay one's Avatar
Default Re: (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ltsmith05 &raquo;</TD></TR><TR><TD CLASS="quote">Tomorrow I'm going to drop it down and let it sit on the wheel with a full load for a bit and then see if I can't get the damn thing tight. </TD></TR></TABLE>
thats not gona work when the weight is on the car is trying to push the nut off putting a jack under the control doesnt work. mines been loose with coter pin for some time now no problems im sure itll fly off some day though its not like it hasnt happened to me before anywase.
Old Dec 21, 2006 | 09:08 PM
Darrell Bs 10SecEG's Avatar
Hey dont drive that car.Its very dangerous.My friends had the same problem and the nut came loose and slipped through the cotter pin and he was doing 70mph on the freeway and hit a bump and the car went to the right crashing into an SUV and then spun in 2 360s hitting 2 more cars and hit the wall and he had a alot of face and head injury.Trust me.Get a new part and replace it or youll be in debt like him of 3 cars suing him for over 100,000 in damages.Be careful bro,Darrell
Old Dec 22, 2006 | 12:00 AM
4thgenhtch's Avatar
Default Re: (Darrell Bs 10SecEG)
No doubt.. Please just replace the damn balljoints!!! Its like 1-2 hrs to fix it right and be done, pull the retaining clip out, pound the balljoint out from the bottom/stud, the pound the new one in and put the clip back on there.. they are like 20-40 bucks..
Every one telling him to just use a stripped out balljoint
Old Dec 22, 2006 | 08:14 AM
Ltsmith05's Avatar
A bud of mine is bringing over his compressor and impact tonight. This is the route even the friend of mine that is a Honda Certified mechanic recommended to take. Thanks for all the help!
Old Dec 22, 2006 | 02:16 PM
Ltsmith05's Avatar
The impact wouldn't fit but instead we sandwiched the castle nuts on (the old and the new with a cotter pin in the middle). Seems pretty sound to me.
Old Dec 22, 2006 | 02:39 PM
crXXXalex858's Avatar
get a impact gun man its the best thing! or have someone stand on top of the rotor/brakes with alot of weight then try wrenching the bolt. spray some wd40 too, maybe the tread has dirt on it and its making the bolt get stuck to it.
Old Dec 22, 2006 | 04:54 PM
Tyson's Avatar
chase the threads with a die. and tap the old castle nut.
the threads on the castle nut will stretch. they need to be rethreaded before reusing. im just saying this out of tons of experience. it helps a lot to have a good custom set of metric and honda compatible tap and die, for all occasions.
common honda sizes you should have.
8x1.25
10x1.25
12x1.25
Modified by Tyson at 6:15 PM 12/22/2006
Old Dec 22, 2006 | 09:05 PM
Ltsmith05's Avatar
Still have a pop. I'm guessing that maybe the bottom is bad too.
Old Dec 23, 2006 | 11:26 AM
Ltsmith05's Avatar
Well, Advance is going to warranty the thing so I yanked the thing off today (took a dremel drill to the nut), and I'm gonna give it a go at again tomorrow. I'd rather be safe than sorry, and since its free its a pretty easy decision to make. It was still popping at times too, which made me nervous. Easy decision. I bought a lower today too, JIC.
Old Dec 24, 2006 | 10:39 AM
hotrodlincoln's Avatar
if your friend is honda certified why are you asking us do what you want leave a messed up ball joint on and die a horrible death when it fails
Old Dec 24, 2006 | 11:59 PM
4thgenhtch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ltsmith05 &raquo;</TD></TR><TR><TD CLASS="quote"> I bought a lower today too, JIC.</TD></TR></TABLE>
Old Dec 25, 2006 | 12:35 PM
Ltsmith05's Avatar
Default Re: (hotrodlincoln)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrodlincoln &raquo;</TD></TR><TR><TD CLASS="quote">if your friend is honda certified why are you asking us do what you want leave a messed up ball joint on and die a horrible death when it fails</TD></TR></TABLE>
Wow. Punctuate please. I started asking here first, then was able to contact my friend. Complicated thought process, I know.
P.S. If you read below you would see that I went ahead and replaced it. /footinmouth
The new one is on and things are perfect. Nothing stripped and no pops. Thanks for the input!
Old Dec 26, 2006 | 12:29 AM
Im glad U listened.Just didnt want to see U get hurt in an accident.Have a safe X-mas and new Years.Darrell
Old Dec 26, 2006 | 03:41 AM
92civicfreak's Avatar
now its time to do the other one :D
Old Dec 26, 2006 | 08:23 AM
Ltsmith05's Avatar
Default Re: (92civicfreak)
I'll be getting myself ready.
Juans_MX3
42
Jul 10, 2021 04:38 PM
chibiko
Jun 6, 2007 08:45 PM
Takumi Fujiwara
Oct 12, 2005 02:55 PM
EriK20
Dec 10, 2004 02:39 PM
nugget8000
Aug 27, 2001 09:37 PM
