Spark plug seals inside the valve cover
Old Dec 21, 2006 | 01:25 PM
Ritchie's Avatar
Default Spark plug seals inside the valve cover
so my spark plug seals are getting old and hard inside my valve cover and i bought some new ones for replacement. i tried to take them out, but it feels like they are stuck onto the metal. any idea or ways to remove them?
Old Dec 21, 2006 | 01:29 PM
Slamaccord's Avatar
Default Re: Spark plug seals inside the valve cover (EGnewbie)
Flat head screwdriver and gently pry on them making sure
not to damage the metal on the valve cover.
Old Dec 21, 2006 | 01:53 PM
Ritchie's Avatar
Default Re: Spark plug seals inside the valve cover (Slamaccord)
you getly pry around the seal?
Old Dec 21, 2006 | 02:02 PM
Slamaccord's Avatar
Yes sir. You are replacing them aren't you ?
Old Dec 21, 2006 | 02:33 PM
Ritchie's Avatar
yes, i'm trying to replace them since i got some new ones from this packet i bought a while ago. the thing is that the center rubber peeled off now i can't seem to get the edges off. any idea how to fix it or is there a shop that can help clean it?
Old Dec 21, 2006 | 02:44 PM
schardbody's Avatar
the edge of them is a metal ring, get a very thin bladed screwdriver and small hammer, tap the screwdriver blade between the edge of the seal and the valve cover. dont be too worried about knicking the valve cover a little, after you get the new ones in squarely use a little RTV silicone and lay a small bead on the edge, that will take care of any imperfections.
Old Dec 21, 2006 | 02:45 PM
Cream's Avatar
im not sure why you cant pry it but the flathead should work pics would be helpful
Old Dec 21, 2006 | 02:51 PM
schardbody's Avatar
Default Re: Spark plug seals inside the valve cover (Cream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cream &raquo;</TD></TR><TR><TD CLASS="quote">im not sure why you cant pry it but the flathead should work pics would be helpful </TD></TR></TABLE>
well, the piece of metal inside the actual seal is VERY thin, and hard to get anything to grab it to pry it, thats why you have to use the screwdriver to bend it away from the valve cover, then pry it out or grab it with a pair of pliers.
Old Dec 21, 2006 | 02:55 PM
Ritchie's Avatar
let me see if i can post some pictures.
Old Dec 21, 2006 | 02:59 PM
Ritchie's Avatar
Old Dec 21, 2006 | 04:38 PM
schardbody's Avatar
whats the pic for??? do what i told you to and they will come out.
Old Dec 21, 2006 | 06:55 PM
Ritchie's Avatar
Default Re: (schardbody)
the rubber seal are stuck to the metal. i don't think using some pliers will do.
Old Dec 21, 2006 | 07:29 PM
GreenEHDriver's Avatar
Default Re: (EGnewbie)
a pocket sized flat head screwdriver and some time they'll come out.
vladvv
Honda CR-V & Element
Sep 20, 2012 08:20 PM
brucepick
Jan 22, 2011 08:51 PM
powerslide360
Apr 26, 2006 12:51 AM
CRX Si
Oct 23, 2003 06:44 PM
Dirk McGirk
Oct 5, 2003 05:56 PM
