Help with injectors??????
I have a 93 civic ex it is turbocharged and have a complete MSD set up and and also i have built up the block and also have a VAFC-2, and many more goodies. So basically everything is built up except the injectors and id like to push 15lbs of boost but what kinda fuel injectors should i go with for 15lbs of boost?? and also are civic injectors a high impedence or low impedence injector?? is a 440cc good enough?? any help plzz
jared
jared
Civic injectors are saturated (high imp). As far as I know (dont quote me on this cause I could be wrong) 440's with your vafc should work fine.
ditch the vafc and get something programmable. psi means nothing. how much power do you want to make? this will determine what size injectors to get.
