need a help with injectors issue
Old Oct 13, 2001 | 02:12 AM
Cyber ITR's Avatar
Default need a help with injectors issue
hi, my car is on progress of turbocharging @ the moment
im confused how many injectors should i use ?
i wanna use the standard 4 B18C injectors , plus the extra injectors
the extra injectors are 550cc out of 13B Series 6 RX7
i just wanna run like low boost , consider my block still standard
thanks in advance
Old Oct 13, 2001 | 03:26 PM
G's Avatar
G
Default Re: need a help with injectors issue (VTEC_SiR)
What would you use to drive the extra injectors? For low boost, you could get some prelude injectors and a VAFC + FMU. If you already have a MF2 or additional injector driver, two 550cc injectors is good up to ?? horses (I think 150 extra horses) assuming the fuel flows evenly to all 4 cyls at 80% duty cycle and 44psi fuel.
Old Oct 14, 2001 | 06:52 PM
Cyber ITR's Avatar
Default Re: need a help with injectors issue (G)
ill be using TurboLink ( some piggyback compie to control the extra injectors )
how big are prelude injectors ?? and will they fit straight away into my B18C fuel rail ?
thanks for ur help
Old Oct 14, 2001 | 07:47 PM
Dee's Avatar
Dee
why don't you just use (4) 550cc FC RX-7 injectors with a resistors installed and a stand alone ECU...
Old Oct 14, 2001 | 07:55 PM
JM Performance's Avatar
Default Re: need a help with injectors issue (drealgsr)
probably because its expensive!
Old Oct 15, 2001 | 12:39 AM
Cyber ITR's Avatar
Default Re: need a help with injectors issue (00SilverLS)
my reasons :
1. yes its expensive
2. i think it will be too much fuel if i run 4x 550cc injectors for running low boost only
so im still thinking whether just to use 1 or 2x 550cc injectors along with my standard B18C injectors
Old Oct 15, 2001 | 01:13 AM
B18C-EJ1
Guest
Posts: n/a
Forget both.
Get RC 440cc injectors and a Hondata Stage 4 system. Call it a day.
Old Oct 15, 2001 | 05:43 AM
4dGSR at work's Avatar
Default Re: need a help with injectors issue (B18C-EJ1)
what did the 550cc injectors run you??
i need 4 of them myself
bdity1@hotmail.com email me please
Old Oct 15, 2001 | 05:50 AM
VTC_CiViC's Avatar
Default Re: need a help with injectors issue (4dGSR at work)
If you're gonna be going with mild boost, just go for some 440 RC's with a V-AFC to turn them down at partial throttle. Can't go wrong there since you'll have low pressures in your fuel system and you'll be able to go with a stock or high-volume intank pump, no inlines needeed. his is of course assuming you don't wanna go with a standalone which will let you tune a set of 440's to even further lengths.
uncledan
Aug 21, 2008 07:46 AM
jdmsijdm
Nov 28, 2003 05:07 PM
VaporTrail
Feb 11, 2002 09:23 PM
