SOHC N/A Piston Question
Alright guys i honestly searched but couldn't find anything so yeah. im running SOHC ZC and i was just wondering if the pistons from an 88-89 integra (D16A3; D16A8/9) would be any good. i've heard that i should use those. im trying to go w/out resorting to boost so yeah. any replies would be helpful. thanks.
Dont remember off hand... But they are the same ones out of an 86-89 dohc 1.6l integra
Call and talk to Tom Jung at ARIAS Pistons 310-532-9737 He can tell you exactly what you need
nice nice. do you know if "knifing" the crank helps at all? a buddy of mine told me that it'll rev like a bike or somethen like that. i thought that was pretty interesting. but yeah so p29 pistons it is then. sounds good.
I very much doubt pm7/p29 pistons come in the sohc zc. From what I understand the earlier sohc zc is almost identical to the d16a6. The only reason the dual cam ZC or later Integra motor has fat dome piston is because it has a very large combustion chamber--I think its like 43cc. Even with the big dome, the 88-89 Integra motor still only has like 9.5:1. Add to the fact that even in the Integra I believe the piston sits 0.040" in the hole. So assuming the sohc zc has the same combustion chamber size of an a6 (38cc) it would have to sit like 0.080" down or something to have compression in the 9s using a p29.
One reason I don't like the p29 piston in theory is because it has such a large dome and it sits 0.040" in the hole on an undecked block. In practice it seems to work fine, but you could have a lighter piston that is "flatter" just by having a taller compression height so it won't sit so far down and have "wasted space".
