Problem setting b20vtec timing
Old Dec 21, 2006 | 07:30 AM
peanuts8888's Avatar
Default Problem setting b20vtec timing
I've adjusted my distributor until it can't move any futher and my timing is still off. I had the block decked and the head machined to ensure a good seal. I'm using a OEM head gasket. I have adjustable cam gears (0,0) and crome for tuning (p72 base map). How do I fix the problem?
Old Dec 21, 2006 | 05:16 PM
wshondaman's Avatar
Default Re: Problem setting b20vtec timing (peanuts8888)
what is your problem exactly? how do you know or what makes you think that your timing is off? do you not have good compression?
Old Dec 22, 2006 | 05:59 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peanuts8888 &raquo;</TD></TR><TR><TD CLASS="quote"> I had the block decked and the head machined to ensure a good seal. I'm using a OEM head gasket. I have adjustable cam gears (0,0) and crome for tuning (p72 base map). How do I fix the problem?</TD></TR></TABLE>
With the head and block machined, your cam timing is retarded. The proper way to set it is to degree the cams. Failing that, +2, +2 is a good place to start if the block and head have been machined substantially. As to your ignition timing, your Crome map will determine what your ignition timing should be at idle. A basic P72 map calls for 16.5 degrees at idle, but jumps to 20 degrees at 1200 rpm. If your car idles higher than 1,000 rpm your timing will advance accordingly.
rol1in0n20s
Nov 25, 2007 08:27 AM
pb16b
Sep 22, 2004 07:54 AM
1 2 NV
Apr 26, 2004 04:27 PM
mtber
Feb 28, 2004 12:11 AM
spooledex
Dec 30, 2003 09:45 AM
