Compression of a stock ITR motor? I may go check a ITR out in NJ
Old May 12, 2002 | 07:01 PM
BrandonClaps's Avatar
New User
Default Compression of a stock ITR motor? I may go check a ITR out in NJ
What is the compression of a stock ITR motor supposed to be? I may be going to look at another ITR in NJ and i wanna do a compression test on the engine. Also do you know if we brought it over to an acura dealership if they would check everything out for me for a price. Anyone do this before? Do they put it in writing so if something isn't right or the guy paid them to lie i can go after em?
-Brandon
P.S. Someone post some pics of FBP itr's!
Old May 12, 2002 | 07:09 PM
t's Avatar
t
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (BrandonClaps)
-Brandon
You can pay a dealership for them to check it out. Anything wrong should be in writing. I dont think dealerships would do business that way.
Old May 12, 2002 | 07:12 PM
New User
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (t)
ok cool, would they go thru it and mark down like scratches or body panels that have been repainted or replaced? Like a THUROUGH job? What about a compression test?
Old May 12, 2002 | 08:45 PM
New User
ttt
Old May 12, 2002 | 09:00 PM
Louie's Avatar
What would Chente do?
Just tell them you want a buyers inspection but you must be specific. Compression test is not a normal inspection item but tell them what you want looked at and they will charge you accordingly. A little money at first may save you a lot later.
Old May 12, 2002 | 09:03 PM
SwiftTypeR's Avatar
New User
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (vagoITR)
i just did me and my friends R compression and we pulled out 242 on 3 cylinders and 1 at 238.
Old Feb 14, 2005 | 05:06 PM
kaj's Avatar
kaj
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (SwiftTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwiftTypeR &raquo;</TD></TR><TR><TD CLASS="quote">i just did me and my friends R compression and we pulled out 242 on 3 cylinders and 1 at 238.</TD></TR></TABLE>
sorry to bring back an old thread.. but is that correct? mine is 235-240 all the way accross... seemed high to me.
Old Feb 14, 2005 | 05:26 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (kaj)
210
Old Feb 14, 2005 | 05:31 PM
Trev-R's Avatar
Mine is 250 across.
Old Feb 14, 2005 | 05:45 PM
TypeRlove's Avatar
Default Re: (Trev-R)
238 on all 4 when i had mine checked.
Old Feb 14, 2005 | 05:53 PM
97mini-me's Avatar
Default Re: (TypeRlove)
230-235
Old Feb 14, 2005 | 05:56 PM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
242 across....
Old Feb 14, 2005 | 05:58 PM
No's Avatar
No
is this a wet test or dry?
Old Feb 14, 2005 | 06:55 PM
Bbasso's Avatar
» Search Results
Your search for compression returned 36 results.
https://honda-tech.com/zerothread?id=960219
Looking To Purchase ITR? Car buying tips
https://honda-tech.com/zerothread?id=641180
https://honda-tech.com/zerothread?id=588192
https://honda-tech.com/zerothread?id=443880
Good luck on buying the ITR.
Old Feb 14, 2005 | 07:01 PM
Nameless RB26's Avatar
Default Re: Compression of a stock ITR motor? I may go check a ITR out in NJ (Bbasso)
Bollucks!!
Old Feb 14, 2005 | 08:22 PM
kaj's Avatar
kaj
haven't heard of a wet/dry test..? anyway, it sounds like mine are right where they should be. sweet!
Old Feb 14, 2005 | 08:38 PM
Default Re: (kaj)
There isn't a 'there'. If numbers are consistent, then that's all that matters.
All low consistent numbers = bad gauge, good engine.
All high consistend numbers = good gauge, good engine.
All low inconsistent numbers = bad.
All high inconsistent numbers = bad.
That's the *general* rule I use when doing comp tests.
When it comes to actually DIAGNOSIS after a compression test.. you do a cylinder leak down.
Compression tests are not always acurate. They do not tell you what is wrong with your engine. They do nothing but give you a general *IDEA* of good/bad or ok.
When you do a compression test the engine MUST be at operating temp. Not warm. Not cold. You do it immediately following shutoff.
Throttle open.
All plugs removed.
6 or 8 cranks on each cylinder. Not 6 here, 8 there. The same on each cylinder.
Dry compression tests are worthless and usually innacurate.
I hope this info reaches people in searches.. because this topic has high frequency here.
94typeR
May 7, 2007 04:32 PM
90lsvcrxva
Apr 9, 2007 02:55 PM
ITR77
Jan 12, 2004 08:04 PM
TEAM562racing
Oct 15, 2003 01:55 PM
