Squeaky Clutch
Every time I push the clutch theres an awful squeaking sound that can be heard in my house if the car is in the garage. Does anyone know what this is or how i can possibly fix it? Thanks in advance.
mine does it too. comes and goes though ill probably get it fix soon. been looking at getting one of those Omni Power Quickclutch master cylinders and see how that works out
you need to find out where its comming from, i could be the slave cylinder rod that pusishes the clutch for, grease that ball on the end of the rod and it will go away! pretty common
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">it could be the clutch pedal bushing I have had that
If his clutch pedal bushing is that loud to where it can be heard in his house, holy ****! Wear some ear protection at all times while driving.
Mine does it to. It seems to come and go. Pretty sure mine is the slave cylinder.
Like said above, find out where it's coming from.
Best way to do this is have a buddy stick their head under the hood, honk once, wait for the profanities to subside, push clutch repeatedly and have your buddy listen to where its coming from. Then grease away or replace.
Grease up the ball and socket looking thing on your slave cylinder. If you pull the boot off you'll see what I'm talking about.
If it's more of a squeal your throwout bearing is on it's way out.
If greasing up the ball/socket thing doesn't do it, find a way to get some grease on the shaft that your clutch sits on. Get some grease down in there somhow. Make sure you don't get any on the clutch disc itself though or you'll be hating life.
all my squeaky clutches have been the slave cyl.
but this guy looks like he has the best advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Grease up the ball and socket looking thing on your slave cylinder. If you pull the boot off you'll see what I'm talking about.
DenisR
Feb 19, 2016 05:09 PM
s1ngle
13
Sep 21, 2005 12:01 PM
