OBD0 injector RESISTOR BOX QUESTIONS (not OBD0 -OBD1 conversion)
i have a 1990 acura integra with a turbo. its OBD0 and i wanted to know if i can just remove the resistor box and use OBD1 injectors. but i dont want to do the conversion. i just want better flowing injectors and that resistor box does not help.
wat are some solutions for me to be able to use better flowing injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TURBOTEG »</TD></TR><TR><TD CLASS="quote">i have a 1990 acura integra with a turbo. its OBD0 and i wanted to know if i can just remove the resistor box and use OBD1 injectors. but i dont want to do the conversion. i just want better flowing injectors and that resistor box does not help.
wat are some solutions for me to be able to use better flowing injectors? </TD></TR></TABLE>
huh what?
Are you injectors maxing the duty cylce or are you just guessing? You want to stay obd0 and up the size correct?
huh what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TURBOTEG »</TD></TR><TR><TD CLASS="quote">im just guessing because with the turbo i assume my stock injectors cant keep up.
and well yeah i want to go bigger. </TD></TR></TABLE>
do some searching here on the 440cc from a DSM first step imo.
You really should get the car tuned and see how your injectors are doing, on that note what are you using to mange it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TURBOTEG »</TD></TR><TR><TD CLASS="quote">wat do you mean "manage it"</TD></TR></TABLE>
What kind of E-mangment are you using?
How are you controling the car whats used to tune it
is your car set up on zdnye, tubo edit, fmu, afc hack etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TURBOTEG »</TD></TR><TR><TD CLASS="quote">FMU</TD></TR></TABLE>
Ew.
I'd look into upgrading the whole seupt fuel and mangment wise.
search and read up on turbo edit... had I stayed obd0 i would have used it, I now am obd1 and quite happy with it.
Ew.
Randysi
Apr 4, 2012 10:17 AM
racingant
Sep 28, 2005 05:10 PM
HiProfile
Jun 20, 2005 02:34 PM
D.Dappa
Jan 18, 2005 06:56 AM
