another bouncing tach and misfireing thread.
Old Dec 20, 2006 | 10:03 AM
delsolnewkid's Avatar
Default another bouncing tach and misfireing thread.
i've got a b18c1 in my del sol, with a turbo on it, was tuning it the other day when the tach started bouncing around at 5k rpms in WOT. REPLACED THE DISTRIBUTOR, and it's still bouncing tach and now it's started misfiring while WOT around 5k rpms. the ecu is good, we put it in another car and it runs fine, we replaced the wires, looked at the spark plugs, and now we're out of ideas.
A/F ratio looks fine also.
anyone have any ideas/suggestions?
Old Dec 20, 2006 | 10:12 AM
95 integra's Avatar
Default Re: another bouncing tach and misfireing thread. (delsolnewkid)
What year swap? Wiring issue maybe??? My guess is the misfire is because the ecu doesnt know what rpm you're at and is sending all kinds of mixed signals to the dizzy. Is the distirbutor plug original or did you do an OBD I conversion on it?
Old Dec 20, 2006 | 10:47 AM
it's an obd1 engine in an obd1 car, so there was no "creative wiring". no error codes or anything
Old Dec 20, 2006 | 10:53 PM
JWHATCH23's Avatar
i know it says you got a new distr. but why dont you try this take it back and get the old distr. and buy a new coil and ignitor mine was doing the same thing about a week ago in my gsr i took an obd1 ignitor and coil out of an obd1 integra ls works fine now
Old Dec 21, 2006 | 06:03 AM
rdssk8rcs1's Avatar
Default Re: another bouncing tach and misfireing thread. (JWHATCH23)
if that doesn't work check the black and yellow wire coming off the distributer, make sure it isn't pinched anywhere, its the output wire from the distributer to the tach, if it hits any bare metal it will mess up the whole cam reading and throw the entire ecu and causes the car to jump around with the tach.
does it only happen at WOT? Or is that the only time you notice it? Any relation to bumps in the road
Old Jan 2, 2007 | 01:52 PM
Default Re: another bouncing tach and misfireing thread. (rdssk8rcs1)
sorry i took so long to post my soloution, i been out enjoying the car. it was a bad ground wire, the small one that goes to the top of the tranny.
DaX
Oct 19, 2017 03:01 PM
Muckman
Jul 3, 2013 10:20 AM
sosasauce
Jul 12, 2010 06:10 PM
delsolnewkid
Jan 2, 2007 01:52 PM
boostedteg15
Aug 4, 2006 06:55 PM
