broken door lock help
Old Dec 20, 2006 | 07:22 AM
jamesc2123's Avatar
Default broken door lock help
I recently bought a '92 si and both doors only lock with the key from the outside, the inside levers are broken. is this a common problem, and what do i need to fix it?
Old Dec 20, 2006 | 07:49 AM
Project_DX's Avatar
Default Re: broken door lock help (jamesc2123)
Go here, put your info in and look up the part you need, then replace it......http://www.hondaautomotiveparts.com/
Old Dec 20, 2006 | 07:55 AM
SkoundrelUSA's Avatar
cute little bastard
the little piece on the "lock switch" probably snapped. happened to me also. I went to the junkyard and pulled a bunch out of Civics.
Old Dec 20, 2006 | 11:06 AM
instructor74's Avatar
Default Re: broken door lock help (SkoundrelUSA)
If it is broken sad to say but you will have to buy the inner handle assy from honda at around 75 i think. Best place to look is the junk yard. good luck some yards will only sell comp. doors and not parts off them
Old Dec 23, 2006 | 02:56 PM
jhelms54's Avatar
I have the same problem, how much for one of the ones you puled from the junkyard? Is it a 92-95?
import_boi
Acura TSX
10
Aug 28, 2011 10:37 AM
WhiteOnRice
Apr 27, 2010 01:19 PM
jimmy o.
Nov 27, 2008 01:14 AM
lillthingz
Feb 4, 2005 03:28 PM
phils2k
Honda S2000
Sep 30, 2004 05:33 PM
