parts needed to swap an ITR engine in a Del Sol
wassup, my freind has a 94 del sol and he has an ITR engine with trans,wiring harness and shift linkage. ITS A USDM motor. will the stock mounts off his D16 engine work with the ITR engine?
what axles are needed, will the stock wireing harness work? a rechipped ECU is needed, will a P28 chipped one work or whats the story? if anyone has performed this swap please let me know what exactly is needed to drop this engine in, thanks to all that respond.
Del Sol VTEC (B16A) engine mounts, axles, and shift linkage...that's it...good luck!!!
[Modified by FreeMyndz, 1:58 AM 5/13/2002]
JDM CRX
Aug 29, 2003 06:12 AM
