Does Anyone Have A Good FULL Write-Up Of How To Swap A D15?
Like It Says, ive searched and most of the archived results are douches looking for " the best engine to swap into" their cars.
any info/links would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y »</TD></TR><TR><TD CLASS="quote">HELMS honda factory service manual
X2
http://helmsinc.com
best way to start the project
when I did a swap (same one you want to do)
it was a no-brainer, just follow the steps
the manual is priceless
3volumes, covers EVERYTHING
it's the same info the mechanics pull up when you take it to the shop
</TD></TR></TABLE>X2
http://helmsinc.com
You mean how to swap IN a D15B VTEC? Or out the D15B for something else? This does matter, because swapping something else in depending on the engine isnt a "one size fits all" kind of write up...
But heres my write up on swapping IN a D15B VTEC (the only D15B worth swapping IN) into a CRX Si...
http://www.efsource.net/tech/D...p.php
its so easy, just make sure you mark anything u disconnect, and keep all the bolts and nuts in once place. take your time, and give yourself atleast 2 days to do it. i did my first engine swap ever with a D15B2, me and a buddy owned it in a day and morning including changing the clutch, and putting on a new tranny. most everything only can go on one way, so its hard to mess up. good luck.
Dan
Dan
go get a helms otherwise you will end up with a chilton manual that will say something like "remove engine, install in reverse order"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">go get a helms otherwise you will end up with a chilton manual that will say something like "remove engine, install in reverse order"
for real that manual sucks..it does say some bullshit like that " drain fluids,remove engine mounts,remove wiring,remove engine with a hydraulic engine hoist,, To re-install reverse process" What type of **** is that? definately get a helms for the hondas
</TD></TR></TABLE>for real that manual sucks..it does say some bullshit like that " drain fluids,remove engine mounts,remove wiring,remove engine with a hydraulic engine hoist,, To re-install reverse process" What type of **** is that? definately get a helms for the hondas
stevocivic
Honda Civic (2001 - 2005)
May 31, 2006 10:25 PM
