painting valve cover
Old Dec 19, 2006 | 06:00 PM
chadalac1712's Avatar
Default painting valve cover
i want to paint it. when types of paint do i use? thinking red with a black vtec on it. and yes im takin it off so dont be an *** and say anything bout that. and plz dont discriminating comments. im new to this stuff.
Old Dec 19, 2006 | 06:03 PM
hondachris1994's Avatar
Default Re: painting valve cover (chadalac1712)
scroll down and read https://honda-tech.com/zerothread/642479
Old Dec 19, 2006 | 06:04 PM
poison's Avatar
Use aircraft remover to remove the old paint. Then I would recommend using high temp paint. But any will work fine.
Old Dec 19, 2006 | 06:05 PM
Harryflores's Avatar
Default Re: painting valve cover (poison)
search first!
Old Dec 19, 2006 | 06:09 PM
Micha's Avatar
FAILWGN
Default Re: painting valve cover (Harryflores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">search first!</TD></TR></TABLE>
Help, don't hinder.
Old Dec 19, 2006 | 06:10 PM
didnt see that bigass post. cant find it on there 2 must be missing it but poison answered my question. ty
Old Dec 19, 2006 | 06:12 PM
vsmferio96's Avatar
Default Re: painting valve cover (Blu99teg)
Yeah a nice search would be nice but anyway... I've painted a dozen or more and just make sure you use a nice stripper to remove any grime and sh*T that might be on it, then a good sandable primer 1-3 coats, then 2-3 light coats of paint, and i usually clear with around 3 coats. Ending up with a baller valve cover.
PS. you don't have to use high heat!
Old Dec 19, 2006 | 07:41 PM
tougeEGsies's Avatar
Default Re: painting valve cover (vsmferio96)
yeah venom and vsmferio96 pretty much said it all, the only thing i would add is after the stripper before the primer use a good cleaner or metal prep. mineral spirits, acetone. just something to get all the aircraft stripper off otherwise you get bubbles and a shitty paint job.
Old Dec 19, 2006 | 07:59 PM
queensm0stwanted's Avatar
When u paint it make sure you use paint that can resist heat cuz it will get hot and the paint will start to peel if u dont get a paint that has a high heat resistance .... Good luck i think they got thread on h-tech so check em out... if i find one ill post it to you
lickety_britches
Jan 2, 2008 01:21 AM
91ED7Si
13
Apr 30, 2007 03:06 AM
maluseanjohn516
14
Dec 8, 2005 06:28 PM
ThatsMyEG
Dec 19, 2004 03:23 PM
tachyteg
Mar 29, 2004 01:03 PM
