***What Kind of Axles 350Hp Turbo***
I'm building my 2000 Si with 9-1 cp or arias pistons eagle rods boring it out to 81.5mm getting arp rod bolts and head studs but is there anyway my stock axles will hold or what kind of axles should i get and if any ones got some gators or somthing good for sale let me know thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Stock axles will hold up. All y ou have to do is launch correctly. </TD></TR></TABLE>
Is that true if your gonna use slicks too? I had a buddy break an axle in his stock d16 lol
I know people in the drag forum have gone 10s with stock axles. My stock replacements lasted longer then my motor doing 8k launches on 24.5 slicks. Its all in the way you launch.
oh ok thanx guys yeah wasn't sure but if not i'll just buy oem if i break them what kind of clutch should i use i have a stage 1 exedy in there right now but i doubt it will hol dup
I dont think youll make enough torque with a B16 @ 350hp to take out a stage 1 clutch, unless you pop the clutch every gear. Any 6puck clutch should be able to hold.
Doesnt Hasport make decent aftermarket axles?
But for the price of most "performance" axles you're better off grabbing a few sets of OEM axles for that price...as long as you know to drive and preaload correctly you shouldnt have any problems with the stockies as they're more reliable than you may think.
Good luck! Let us know what you end up doing.
Yeah i'm going to stay with stock axles then and i'm getting an exedy stage 2 clutch in order to hold the power everything should be done by mid january and i'll show you guys the dyno charts when its all done thanx
I'm gonna tell you a trick.
Buy autozone, napa, etc axles with lifetime warranty. When or if you break, take them back and make up a story, voila, new axles.
turboman
Feb 20, 2006 11:40 PM
