Gauge Cluster Cover
Old Dec 19, 2006 | 04:13 PM
ivan1985's Avatar
Default Gauge Cluster Cover
I am so pissed off right now. I finished installing my tach and everything and now I can't get my cluster cover on. The 2 screws in the back are not going anywhere. I don't know what the expletive is going on. I thought I could get away with the 2 other screws from underneath but it's too flimsy. How can I get those screws in? I am very frustrated right now. Thanks.
Old Dec 19, 2006 | 04:18 PM
STDClayton's Avatar
Default Re: Gauge Cluster Cover (ivan1985)
if you're using the same year hood as the cluster: 88-89 hood with 88-89 cluster/90-91 hood with 90-91 cluster, i don't see what your problem could be.
Old Dec 19, 2006 | 04:21 PM
ivan1985's Avatar
Default Re: Gauge Cluster Cover (STDClayton)
Hood? What are you talking about? I am talking about a cluster cover.
Old Dec 19, 2006 | 04:47 PM
janz3n's Avatar
you mean the plastic bezel or what ever, that has the hazard , cluster light dim switch and defroster switch in it?
Old Dec 19, 2006 | 06:17 PM
ivan1985's Avatar
Default Re: Gauge Cluster Cover (janz3n)
Exactly.
The 2 screws in the back are not tapping in....
Old Dec 19, 2006 | 06:24 PM
Crx Jimmy's Avatar
did the little metal clips the screws screw into fall off?
Old Dec 19, 2006 | 06:40 PM
janz3n's Avatar
in the back?? theres two on top and two on bottom. which ones dont work?
Old Dec 19, 2006 | 06:45 PM
STDClayton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan1985 &raquo;</TD></TR><TR><TD CLASS="quote">Hood? What are you talking about? I am talking about a cluster cover.</TD></TR></TABLE>
hood, cluster cover, bezel cover, whatever...they're all talking about the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">did the little metal clips the screws screw into fall off?</TD></TR></TABLE>
Old Dec 19, 2006 | 06:55 PM
ivan1985's Avatar
The two on top...
Metal clips hey........hmmmmm thats quite possible.......
Where can I get these clips?
Old Dec 19, 2006 | 07:33 PM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STDClayton &raquo;</TD></TR><TR><TD CLASS="quote">
um no the hood on the 90-91's is the piece on top of the cluster setup. so its not the same thing at all. same for the cluster cover.
you really need to have the screws in there.. unless you really care about it.. the two on the bottom will keep it in just fine.. i dont have anyin right now cuz im too lazy to screw them in.
Old Dec 19, 2006 | 08:07 PM
ivan1985's Avatar
Yeah but I have an 5 inch talk attached to it....
Old Dec 20, 2006 | 07:38 AM
janz3n's Avatar
k well i dont think were talking about the same plastic piece then. get a smaller tach lol.
Old Dec 20, 2006 | 07:52 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">k well i dont think were talking about the same plastic piece then. get a smaller tach lol.</TD></TR></TABLE>
Factory tach FTW. Well not really it's pretty useless for me since I max out the needle and so do alot of EFers.
Yes, make sure that the metal clips are in the back they are the only thing that the screws screw into. I lost mine and I just used a bit of double sided tape on the inside and it holds in just fine for now. I probably won't ever fix it cause well...it's just my daily and I don't see playing around so meh.
suspendedHatch
Jan 22, 2007 07:42 AM
slammedcivicsi
Mar 2, 2006 12:22 PM
jedubz
Aug 29, 2005 05:37 PM
dmxsoulja3
Dec 14, 2004 09:01 PM
kevinm1981
Feb 8, 2004 10:49 PM
