Removing clear cover on gauge cluster..
Can someone explain the process to me so I don't screw it up worse I'm trying to swap one awesome non scratched cluster cover for a beat up one.
Thanks, Josh
Thanks, Josh
Re: Removing clear cover on gauge cluster.. (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 »</TD></TR><TR><TD CLASS="quote">it clips in around the cluster just unclip them and it comes right off </TD></TR></TABLE>yea i really dont know how else to describe it. thats it
Re: Removing clear cover on gauge cluster.. (bleh)
Also in addition to the clips pull out the odo/trip reset button. It just pulls straight out. Don't worry it won't break.
Re: Removing clear cover on gauge cluster.. (RedlinedVTEC)
Only on the EG, you need to take out the rubber piece of the trip reset. The EKs you dont. Basically, you unclip one side and work to the other side, and give a little pressure to separate it, otherwise itll reclip.
724chris
02-18-2010 04:32 PM
