whats the quickest and easiest way to change the alternator?
Old Dec 19, 2006 | 07:26 AM
lrcrx90's Avatar
Default whats the quickest and easiest way to change the alternator?
my civic seadn needs the alternator changed and i don't have alot of time to change it so i just help if theres any quick way to take it out so i could exchange it
Old Dec 19, 2006 | 07:36 AM
zccr-xsi's Avatar
drop it from the bottom.
Old Dec 19, 2006 | 08:01 AM
sic944t's Avatar
Default Re: (zccr-xsi)
****** the enigine with a front end loader shake violently until it rips out then you can easily remove the alternator ....... or just get it from the bottom sometimes a 12 or 14 on a longlong extension makes that bottom bolt real easy to get to ....
Old Dec 19, 2006 | 08:02 AM
zccr-xsi's Avatar
taken it out from the bottom means u have to drop the lower alt bracket not hard thing to do.
Old Dec 19, 2006 | 08:11 AM
lrcrx90's Avatar
alright thanks
Old Dec 20, 2006 | 07:39 PM
CarAudioPro's Avatar
Default Re: (lrcrx90)
if you unbolt the brake master cylinder from the booster, it slips rite out.
Old Dec 20, 2006 | 08:22 PM
1 Fly SI's Avatar
Default Re: (CarAudioPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarAudioPro &raquo;</TD></TR><TR><TD CLASS="quote">if you unbolt the brake master cylinder from the booster, it slips rite out.
</TD></TR></TABLE> That is the easiest way.
Old Dec 20, 2006 | 08:31 PM
wiZCo's Avatar
Stouts 'n' Scotch
I've been able to magically finagle it through the driver's fender well before (of course the tire needs to be off).
Old Dec 22, 2006 | 04:47 AM
zccr-xsi's Avatar
thats dumb then u got to rebleed your brakes.drop that **** from the bottom .dont make more work for yourslef.
Old Dec 22, 2006 | 06:45 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">thats dumb then u got to rebleed your brakes.</TD></TR></TABLE>
No, you don't. You don't disconnect the brakelines from the master cylinder. Just the master cylinder from the brake booster. I know because I did it that way this past weekend.
Old Dec 22, 2006 | 07:33 AM
fortunesk89's Avatar
take it to a shop?
Old Dec 22, 2006 | 07:36 AM
mar778c's Avatar
Community Builder
Default Re: (fortunesk89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortunesk89 &raquo;</TD></TR><TR><TD CLASS="quote">take it to a shop?</TD></TR></TABLE>
lol, this is honda-tech. The wierd world of DIY.
Old Dec 22, 2006 | 07:38 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">drop it from the bottom.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">taken it out from the bottom means u have to drop the lower alt bracket not hard thing to do.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">thats dumb then u got to rebleed your brakes.drop that **** from the bottom .dont make more work for yourslef.</TD></TR></TABLE>
IS ANYONE LISTENING TO HIM ^ DROP IT FROM THE BOTTOM THAT IS THE EASIEST.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">I've been able to magically finagle it through the driver's fender well before (of course the tire needs to be off).</TD></TR></TABLE>
Now that is intriguing. Have to check that one out.
Old Dec 22, 2006 | 07:43 AM
mar778c's Avatar
Community Builder
Default Re: (CRX Toad)
Yeah, that is one way of doing it.
The only problem is the drivers side axle is a bear to get out with hand tools, specifically the axle nut.
Old Dec 22, 2006 | 07:45 AM
CRX Toad's Avatar
Default Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, that is one way of doing it.
The only problem is the drivers side axle is a bear to get out with hand tools.</TD></TR></TABLE>
Exactly....and you don't have to take it out. Alt. slips right out....between the engine and the axle over towards the tranny. I can do it in about 15mins now that way had a run of bad alternators on my car....very frustrating.
Old Dec 22, 2006 | 07:46 AM
snowseeker's Avatar
Unbolt the master frm the boost and move on the side with lines still attached. Alt. slides right out without having to crawl under the car or jack up the car at all.
E A S Y
Old Dec 22, 2006 | 09:04 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly....and you don't have to take it out. Alt. slips right out....between the engine and the axle over towards the tranny. I can do it in about 15mins now that way had a run of bad alternators on my car....very frustrating. </TD></TR></TABLE>
Not on a b16a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Unbolt the master frm the boost and move on the side with lines still attached. Alt. slides right out without having to crawl under the car or jack up the car at all.
E A S Y </TD></TR></TABLE>
Yeap
Old Dec 22, 2006 | 10:56 AM
CRX Toad's Avatar
Not on a b16a.
Guess we were talking two different motors then.
Old Dec 22, 2006 | 07:01 PM
zccr-xsi's Avatar
ive been there too.
Old Dec 22, 2006 | 07:18 PM
zccr-xsi's Avatar
look what i found so easy! https://honda-tech.com/zerothread?id=735803.
Old Dec 22, 2006 | 07:30 PM
freshly boosted DOHC ZC's Avatar
the way i have been doing it was bring it under the intake manifold and out the passenger way up through the engine bay. EASY
Old Dec 22, 2006 | 10:40 PM
abnaasefmb's Avatar
Default Re: (sic944t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sic944t &raquo;</TD></TR><TR><TD CLASS="quote">****** the enigine with a front end loader shake violently until it rips out then you can easily remove the alternator ....... or just get it from the bottom sometimes a 12 or 14 on a longlong extension makes that bottom bolt real easy to get to .... </TD></TR></TABLE> lol
just unbolt it bolt in the new one and let the old one just lay there, find a bumpy road and drive like hell, it'll come out.
Old Dec 23, 2006 | 08:42 PM
zccr-xsi's Avatar
Default Re: (almost boosted DOHC ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almost boosted DOHC ZC &raquo;</TD></TR><TR><TD CLASS="quote">the way i have been doing it was bring it under the intake manifold and out the passenger way up through the engine bay. EASY</TD></TR></TABLE>
wont u have to unbolt the fuel filter?
carlthecrx
21
Nov 11, 2007 03:22 PM
Jizzmaster Zero
16
Dec 21, 2005 02:02 PM
kaotikcrx05
Jan 27, 2005 10:11 AM
unknownhero16
Dec 27, 2003 05:41 PM
91 civic
Apr 22, 2003 03:38 PM
