B16A2 W/CTR
Old Dec 19, 2006 | 06:47 AM
StreetFusionR's Avatar
Default B16A2 W/CTR
I wnated to know what exactly must be purchased to install ctr pistons in my B16A2 its in my 00 si I will buy rods if it is the easiest way and was going to put a mugen gasket aswell to help raise compression. please let me know your thoughts.
Old Dec 19, 2006 | 06:59 AM
dbiker207's Avatar
Default Re: B16A2 W/CTR (StreetFusionR)
u need rod bearings, pistons and a ring set. and you need to deglaze the cylinder walls. if your gonna use stock rods you need to have the pins pressed out of the old pistons and into the new pistons
Old Dec 19, 2006 | 08:52 AM
Suck my DX's Avatar
Default Re: B16A2 W/CTR (dbiker207)
deglaze your cylinder walls? what do you mean by that?
as long as the factory crosshatching is present and there are no other scratches on the cylinder walls honing really isnt necessary...
also for the stock rods the ctr pistons wont directly fit...you need to have a machine shop shave(geez im having a brain fart right now its either 1 or 2mm total) material off each side of the rod to fit the piston.
also while you have the bottom end apart it would be a good idea to have the crank polished and rod bolts installed....its not necessary but its something to look into...
Old Dec 19, 2006 | 09:13 AM
( o )( o )'s Avatar
Default Re: B16A2 W/CTR (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">also for the stock rods the ctr pistons wont directly fit...you need to have a machine shop shave(geez im having a brain fart right now its either 1 or 2mm total) material off each side of the rod to fit the piston.
i got CTRs in my b16a2. yes, i believe it is 1 mm off each side of the rod for the piston to fit.
Old Dec 19, 2006 | 01:03 PM
Default Re: B16A2 W/CTR (( o )( o ))
what would be my other option to aftermarket or other oem rods from another engine. I want to do this with no more than a day or two of down time and without pulling the motor.
Old Dec 19, 2006 | 02:29 PM
Furyof4's Avatar
You could have the material machined off the pistons instead of the rods. That way it could be done ahead of time.
B16EKruger
22
May 2, 2005 10:20 PM
CrazyKoreanCrx
Feb 26, 2004 01:45 PM
dickspeed
Mar 27, 2003 05:39 PM
SiSpray
Nov 23, 2002 09:17 AM
One Bad GeeSeeR
Mar 4, 2002 10:23 AM
