ball join hitting frame
Old Dec 18, 2006 | 10:14 PM
CRX 2.0V-T's Avatar
Default ball join hitting frame
Ok so mine car is dropped and now the problem is my upper ball join hit the frame. It hitting because i have a camper kit. What should i do? any1 have the same problem?
Old Dec 19, 2006 | 06:21 AM
EL Vap133's Avatar
Default Re: ball join hitting frame (Lak of Speed)
How low is the car?
Old Dec 19, 2006 | 06:24 AM
civicandy's Avatar
Default Re: ball join hitting frame (EL Vap133)
it must be really low. i dont have my coils all the way down, and i dont have a problem, but it depends on how much added camber you have to. what camber kit are you using?
Old Dec 19, 2006 | 07:50 AM
MatHadder's Avatar
Default Re: ball join hitting frame (civicandy)
Yeah, I think this is a pretty common problem. I made a couple small cuts on either side of the balljoint into the ridge of metal it was hitting, and then took a hammer and bent the metal out of the way.
I am pretty sure this clearance issue is why skunk2 hasnt made a front camber a-arm for the EF
Old Dec 19, 2006 | 08:05 AM
civicandy's Avatar
Default Re: ball join hitting frame (MatHadder)
cusco makes an arm similar to that. i believe its a copy of the vision arms. i doubt there is a solution to the ball joint hitting other than hammering it in. the only way to get positive camber is to either use civic lower control arms if you do a b series swap or make the upper arm longer/adjustable
Old Dec 19, 2006 | 11:40 AM
gospeedgo1's Avatar
revo technica? makes an adjustable upper control arm for the ef chassis. search and you should find a post within the last month about it. if i remember correctly, the vision and cusco arms only add negative camber, you need to adjust it to add more towards positive camber. no one as of yet has reported on how they work on their car but a couple have them mounted on their car.
Old Dec 19, 2006 | 12:00 PM
civicandy's Avatar
Default Re: ball join hitting frame (gospeedgo1)
https://honda-tech.com/zerothread?id=1837022
here's the revo link. I think the Cusco and Vision add positive camber. If you lower the EF more than 2", you gain negative camber. Even for track racing I doubt you would want to add more negative camber. My car is about 3" lowered and has roughly 1.7 deg. of negative.
crx_si-r
Jun 7, 2010 09:29 PM
duggy
15
Dec 8, 2006 03:51 PM
civicgeek133
Suspension & Brakes
12
Nov 26, 2006 06:40 PM
down_the_hatch
10
Feb 17, 2005 06:40 AM
91sihatchback
10
Jul 28, 2003 09:45 PM
