B18 SWAP INTO 98 CIVIC
Old Dec 18, 2006 | 08:05 PM
lee's ej8's Avatar
Default need help b18 swap into a 98 civic
i need help i was wondering if i put a 89 ls motor into my 98 civic coupe wat i would need to put in like wat kinda motor mounts and wat kinda harness can u use if u know can yall help me out here thanks
Modified by lee's ej8 at 10:55 PM 12/18/2006
Old Dec 18, 2006 | 09:37 PM
stock_honda_coupe's Avatar
Default Re: NEED HELP B18 SWAP INTO 98 CIVIC (lee's ej8)
Don't type with the caps lock on. You'll be lucky to get any answers typing like that.
Old Dec 18, 2006 | 09:51 PM
lee's ej8's Avatar
watever dude im just needing help here u dont got to be all rude and ****
Old Dec 18, 2006 | 09:54 PM
hondamilitiaeg6's Avatar
an 89 ls motor is obd0, and the 98 civic is obd2 so alot of wiring would be needed, b series into ek mounts will do the trick, less wiring is involved if you update to a 96+ ls distributor. if you want the swap to be legal the motor should be of the same year or newer than the vehicle though, so your swap would not be legal in all states
Old Dec 18, 2006 | 09:57 PM
lee's ej8's Avatar
thanks hondamilitiaeg6 for some info
Old Dec 19, 2006 | 05:04 AM
vladd's Avatar
Default Re: need help b18 swap into a 98 civic (lee's ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lee’s ej8 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by lee's ej8 at 10:55 PM 12/18/2006</TD></TR></TABLE>
that won't an upgrade at all. they're both 1.6 and slow. look into something that's 96+.
Cjs_slowkey_ej6
Aug 21, 2015 06:59 AM
froogle29
Jul 23, 2008 04:56 PM
mcaro
Dec 17, 2005 07:42 PM
DrifterZ
Nov 2, 2004 07:36 AM
soslow_98
Oct 18, 2004 07:57 AM
