spool gun
Old Dec 18, 2006 | 02:18 PM
Zornig's Avatar
Default spool gun
Anyone ever use one for welding aluminum. Im talking production work.
I used a millermatic210 today for the first time. It welds really nice but keeps burning up the tips. Im talking like every 5 min I had to change it. A Jod that should have taken 1hr took 2. Pertty frustrating
Any help would be great.
TIA
Jim
Old Dec 18, 2006 | 02:44 PM
KFMRC's Avatar
Default Re: spool gun (Zornig)
you might try going one tip size larger .030 wire use .035 tip. You may also try to run a little more wire speed to get the wire slightly further out from the tip a very small amount this will also help keep the heat away from the tip. I have never had that problem but I almost always use the tip trick
Old Dec 18, 2006 | 05:52 PM
Zornig's Avatar
Default Re: spool gun (KFMRC)
I tried the larger tip and it made no difference. I will try to back away from the piece im welding a little more.
thanks for the tips
Old Dec 18, 2006 | 09:46 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KFMRC &raquo;</TD></TR><TR><TD CLASS="quote">you might try going one tip size larger .030 wire use .035 tip. You may also try to run a little more wire speed to get the wire slightly further out from the tip a very small amount </TD></TR></TABLE>
That's what I do and it works fine.
Old Dec 19, 2006 | 02:06 PM
Bjorn's Avatar
what thickness, speed, joint type, etc.
I used one in class (mastered it in 1hr.) - Lincoln 250 with the expensive gun on 14g
found out that changing even .2volts made the difference between perfect and not qutie good enough. Al also likes high feed speed - used setting 9 on the gun to keep heating building up too much on 14g
I'd imagine you need to crank up the speed a bit and push at a steeper angle than mild - dragging equals more heat, which travels up the wire, heating it up, causing less voltage needed to melt it, meaning starting voltage is too high after a few seconds
96 GSR-T
Welding / Fabrication
Apr 12, 2010 05:09 AM
MidwestAutoWorks
12
May 17, 2007 06:57 AM
BEEYOND
Feb 22, 2006 05:30 PM
gutterslide
May 25, 2005 06:39 PM
BoostedH23a1
Aug 10, 2003 07:15 AM
