about to buy jdm d15b, need advice
Old Dec 18, 2006 | 11:26 AM
dxhatch92's Avatar
Default about to buy jdm d15b, need advice
Theres a guy selling a jdm d15b longblock without dist and intake manifold. i have a 92 civic dx, and i know a z6 dist will fit on the d15b, but will the b7 dist work on it? he also said the motor mount got loose somehow and caused the bolt to grind on the tooth of the timing belt, but he said the motor still runs fine. is there anything i should look for? should i do a compression test or anything? thanks for the help!
Old Dec 18, 2006 | 12:31 PM
dxhatch92's Avatar
up
Old Dec 18, 2006 | 03:29 PM
Bense's Avatar
your b7 dizzy won't bolt up, unless you want to use vice grips to hold it on.
i'd stay way from it, unless it's really cheap
Old Dec 18, 2006 | 03:33 PM
Syndacate's Avatar
Default Re: (Bense)
It won't hold a compression if the valves are bent.
So do a compression check.
Aside from that I'd just change the timing belt when you get it - better safe than sorry.
Old Dec 18, 2006 | 04:07 PM
dxhatch92's Avatar
thanks for the help. that guy is asking $200. is that a good deal?
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
junior_tm
Feb 1, 2011 07:30 PM
trevdawg
May 31, 2010 05:44 PM
twentyhurtz
30
Dec 2, 2009 02:28 PM
RockLee`
Oct 29, 2006 03:43 PM
