Idle Problems! Parts Replaced STILL NOT WORKING!YHELP!
1990 crx poorman's set up. Idle Problem. It idled at 3k and then went down to 2k after I found a leak in the back of the intake manifold. I thought it was my thermostat because it was shot to hell so I replaced and still. I bled the coolant system and everything. Reset the ECU and still nothing.
Anyone have any suggestions??
Help!
Help!
try the dashpot diaphram on the throttle body -
hard for me to explain when I'm not looking at the engine right now, but there is a round metal piece attached to the exterior of the throttle body, and there is a small piece of metal rod coming out of it - while the car is idling, push the metal rod into the dashpot diaphram and see if that brings your idle down - if that is it, you need to find a replacement (unless someone knows a trick to fix this) - hope this helps.
Another thing after I replaced my thermostat My RPM gauge wasn't working and still doesn't...any other suggestions.
It idles at 2,500 rpms and then dies down to 0 and back up .......but yeah..
thewrai6th
Oct 28, 2018 05:32 PM
dth0ng69
Mar 17, 2009 08:31 PM
