2000 Accord P1456 Code Questions
I got the code at auto zone today and have been doing some reading on it. It seems that the easiest possible fix is to tighten the gas cap. I did this and my wife is driving the car right now.
Will the check engine light go out on its own if this solves the problem.
If not, how do I reset the light. I saw one thing that said remove the #13 fuse for a minute and that will reset the light.
Also if the light resets, will it come right back on if there is no pressure in the tank.
Thanks
Thanks
P1456 is the code you'll get from a loose gas cap, but there's a handful of other (less likely) problems that can cause the same thing. They mostly amount to a gas tank that isn't airtight like it should be.
I think that code takes several 'driving cycles' before it sets itself, so if you still have a problem, the light might not come back for a couple days. Hopefully it was just the cap & it never comes back.
WamAccord
Jul 2, 2004 08:56 PM
