i have a problem with my rex doing the mexican hat dance !!!!!
Old Dec 17, 2006 | 08:22 PM
rex-rated's Avatar
Default i have a problem with my rex doing the mexican hat dance !!!!!
ok when im at a stop i put it in first to take off its starts reving up and down it acts like it wants to turn off and the check engine light is on but when i put it in 2nd gear the light turns off and it stops doing it and ive tryed everything the fuel system the ecu and the map sensor even the main relay and its not doing it too bad anymore after the relay but its still doing the same thing if anybody will help out and let me know if they have any ideas that would be great thanx.......
Old Dec 17, 2006 | 08:42 PM
hybridmiklo's Avatar
Default Re: i have a problem with my rex doing the mexican hat dance !!!!! (rex-rated)
I think it has something to do with your idle air control valve.
Old Dec 17, 2006 | 08:49 PM
JokerX-1.6T's Avatar
yea take it off and clean the screen off possibly if thats the problem but either way depending on the mileage you may want to check it anyway mine was doing something similar no engine lights though and that fixed it for me
Modified by JokerX-1.6T at 10:59 PM 12/18/2006
rex-rated's Avatar
Default Re: i have a problem with my rex doing the mexican hat dance !!!!! (hybridmiklo)
i havent tried that ill try it and get back to you on that thanx bro i appreciate it ....
Old Dec 18, 2006 | 06:39 PM
ever get it figured out ?
Old Dec 18, 2006 | 06:47 PM
xotic_crx's Avatar
Default Re: (JokerX-1.6T)
That sounds similar to what mine's been doing, the idle will search between 1500-500 after it warms up, sometimes....
Old Dec 18, 2006 | 06:59 PM
try what whats been posted and that should help if its the problem and if not you know thats 1 less thing you have to worry about
Old Dec 18, 2006 | 09:33 PM
rex-rated's Avatar
i havent yet bro havent had time been working but ill get to it tomrrow and ill let you know something thanx again bro....
Old Dec 18, 2006 | 09:36 PM
rex-rated's Avatar
yeah i know ive tried everything like the fuel pump ,ecu,main relay map sensor ,a brand new si distrubitor,all kinds of sensors and the wiring to the sensors but didnt try the idle control valve and my idle is at 1500 rpm.
98bucket
Jul 10, 2010 12:15 PM
aznoophi
Feb 21, 2008 12:55 PM
vietboycuhz
Oct 21, 2005 09:27 AM
waijsR
Oct 30, 2003 01:43 AM
irev210
Jun 11, 2003 07:00 PM
