help! cant take out my front axels
Old Dec 17, 2006 | 11:42 AM
jikespingleton's Avatar
Default help! cant take out my front axels
can anybody tell me how to take my axels out. my friends arent helpin me with the swap and im startin to get frustrated. all i have left are the axels and then i can pull the motor out. please help.
Old Dec 17, 2006 | 11:49 AM
lVlemphizStylez's Avatar
Default Re: help! cant take out my front axels (jikespingleton)
take a big flathead screw driver and pry between the axle collar and the transmission to pop it out of the transmission..Taking it out of the disk should be self explantory
Old Dec 17, 2006 | 11:53 AM
Default Re: help! cant take out my front axels (lVlemphizStylez)
i got the big nut off holding my hub on and nothing happened. my hub wont break lose. can somebody just give me a step by step so i can make sure im doin it right.
Old Dec 17, 2006 | 11:56 AM
Undo the suspension fork...Undo the lower control arm...Now the disk can pivot on the ball joint on the bottom...remove big spindel nut that secures the axle in the disk...Knock axle out of the suspension
Old Dec 17, 2006 | 11:59 AM
thank you.
Old Dec 17, 2006 | 12:00 PM
oh and how do i get the lower control arm off the tapered bolt with out a pickle fork?
Old Dec 17, 2006 | 12:03 PM
wha ya mean? you pry the thing off the middle bolt and get the top end of it down from the frame of the car ...there is some free play in it enough to get it off the bolt
Big thick flathead screw drivers are your friend
Old Dec 17, 2006 | 12:07 PM
cool, thank you.
Old Dec 17, 2006 | 12:21 PM
JDM_DC4_Fanatic's Avatar
not to hate, but if you dont know what a balljoint is ("the tapered bolt") I really dont think a motor swap is for you. However, best of luck on the project. If the axel doesnt want to slide out of the hub, spray it with some lube and tap it out with a hammer, dont hit it too hard, you dont want to expletive up the splines. you can only remove it from the tranny when it is free from the hub first. once its free from the hub, pry it out of the tranny.
One question though, if you dnt have to remove the trans to take the engine out, and if the tranny is staying put, so are the axels....
Old Dec 17, 2006 | 12:24 PM
Default Re: help! cant take out my front axels (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
One question though, if you dnt have to remove the trans to take the engine out, and if the tranny is staying put, so are the axels....</TD></TR></TABLE>
Taking the engine out with the transmission is much easier than trying to seperate the two and lift one out while leaving the other...especially when the one youre trying to remove is the bigger of the two
Old Dec 17, 2006 | 12:39 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
Taking the engine out with the transmission is much easier than trying to seperate the two and lift one out while leaving the other...especially when the one youre trying to remove is the bigger of the two</TD></TR></TABLE>
Yea, I've never heard of anybody taking out the engine and leaving the tranny in....I'll assure you its going to be much much harder to do. Trying to seperate the two (with the trans upper and side mount still attached) is going to be a real bitch. On top of that, the half shaft (ie half the axle) is attached to the engine as well.
Old Dec 17, 2006 | 05:50 PM
i know wat a ****** ball joint is and i know how to get them out. i needed some reassurence because everything isnt goin the way it should. i even got a pickle fork to try to the pry the balljoint out and its not budgin. so just keep ur opinions to your self.
Old Dec 17, 2006 | 06:03 PM
95 integra's Avatar
Best way to pop it loose with little effort.
https://honda-tech.com/zerothread?id=887859
Old Dec 18, 2006 | 03:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton &raquo;</TD></TR><TR><TD CLASS="quote">i know wat a ****** ball joint is and i know how to get them out. i needed some reassurence because everything isnt goin the way it should. i even got a pickle fork to try to the pry the balljoint out and its not budgin. so just keep ur opinions to your self.</TD></TR></TABLE>
wait a sec jack ***, first off, you asked for help. second, you didnt call it a balljoint, you called it "the tapered bolt". So, if you knew it was a balljoint, why would you not call it by its proper name? Also, enjoy replacing the balljoint when you ream it out with the pickel fork, why not just hit the lower control arm with a hammer and save it? Ignorance
Old Dec 18, 2006 | 03:17 PM
Ari's Avatar
Ari
* B A N N E D *
why not just hit the lower control arm with a hammer and save it! </TD></TR></TABLE>
Old Dec 18, 2006 | 05:38 PM
i already tried to bust it loose with a hammer. dude, ive worked at shops before. i know wat im doin. every conventional method ive used to work on this car hasnt worked. it sucks, thats why i was askin. sorry for not using the "proper" term.
yeegsr
May 25, 2007 04:35 PM
gursh d
Jan 23, 2007 09:21 AM
Rod.
Jan 23, 2004 09:11 PM
girl m3chanic
Jul 12, 2003 10:48 PM
XEF-9X
18
Aug 15, 2002 10:31 PM
