Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Remote reservoir shock installation
Old Dec 17, 2006 | 10:02 AM
TPB's Avatar
TPB
Default Remote reservoir shock installation
I was speaking with Lex Carson at Moton a couple weeks ago after receiving my order and he told me that to mount the remote reservoir I'd need to cut 3" holes through the car's body. I just read elsewhere that some reservoir lines come with quick disconnects so that you can simply fish the line through a much smaller hole in the body. Unfortunately Motons don't come with this line.
I don't have a problem cutting into my car (DC2) to mount the reservoirs - I just want to explore all my options and do this correctly the first time. I'm looking for pictures and feedback from those that have already done it themselves.
Old Dec 17, 2006 | 10:09 AM
thawley's Avatar
Default Re: Remote reservoir shock installation (TPB)
You might try asking the World Challenge and Grand Am forums, too. I doubt you'll find many moton users here.
Old Dec 17, 2006 | 01:27 PM
slammed_93_hatch's Avatar
On the GAC TSX's i work with, they have the 3inch holes cut in the unibody. No other real option
Old Dec 17, 2006 | 01:45 PM
Andrie Hartanto's Avatar
Moton sells quick release using staublii drybreak connectors. They are expensive and might be the only option. However, be aware, you will still have to have nitrogen, regulator and adapter to fill the canister on the moton.
First, release the nitrogen pressure, disconnect the quick disconnect, then refill the canister.
IMHO, just cut 3" hole. This is how we did it in our NSX too.
Old Dec 17, 2006 | 03:34 PM
TPB's Avatar
TPB
Default Re: Remote reservoir shock installation (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">On the GAC TSX's i work with, they have the 3inch holes cut in the unibody. No other real option</TD></TR></TABLE>
That's what I thought - might you have any pics or direct me to where there may be some?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">Moton sells quick release using staublii drybreak connectors. They are expensive and might be the only option. However, be aware, you will still have to have nitrogen, regulator and adapter to fill the canister on the moton.
IMHO, just cut 3" hole. This is how we did it in our NSX too.</TD></TR></TABLE>
I'm not too fond of releasing the pressure and then recharging it - I'll be cutting the 3" holes. I'll check out the GAC forums for more info.
Old Dec 17, 2006 | 04:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">
I will post up some later tonight, im not at my computer with all of the pictures on it
Old Dec 18, 2006 | 04:08 PM
TPB's Avatar
TPB
Thanks - looking forward to seeing a GAC installation
Old Dec 18, 2006 | 09:46 PM
so i checked and didn't really have that great of pictures of the holes. but here is what i have.
Old Dec 19, 2006 | 05:15 AM
TPB's Avatar
TPB
Thanks slammed_93_hatch
Old Dec 19, 2006 | 10:55 AM
nscirocco's Avatar
here's mine, not a great pic, but..
the holes are covered by a piece of aluminum riveted in place
just watch it's not too close to the exhaust
in the front you don't need to cut anything, just pass the reservoirs near the steering rack and tie em to your strut bar
-nigel.
Old Dec 19, 2006 | 01:12 PM
TPB's Avatar
TPB
Default Re: Remote reservoir shock installation (nscirocco)
Hey I know that car - wasn't that an OCC GTB car a couple years ago? BTW thanks for the photo.
Old Dec 20, 2006 | 07:53 AM
glagola1's Avatar
You can actually use a 2-1/8 hole saw to make the hole. 2-1/8 is the size of the canister and it will fit through that hole. The hose fitting will fit too after the majority of the canister is pushed through the hole and angled just right. Use a piece of SS or aluminum with a slit cut in it (that opens when bent to accept the hose) and rivet that over the hole. Cut a grommet and silicon that in place around the cover where the hose goes through.
Easy. I did this to the trunk of my S2000 and when I sold the motons to build my CRX, I just patched the holes with new stainless steel panels and used the same rivet holes.
Old Dec 22, 2006 | 07:28 PM
Fastom's Avatar
Default Re: Remote reservoir shock installation (glagola1)
Hint: Find the right size rubber grommet first. Then get a hole saw of the right size. Its a lot easier in htis order
Old Jun 4, 2007 | 07:31 PM
TPB's Avatar
TPB
Does anyone know where I can buy the reservoir mounts in the picture? I like the cradle design.
Old Jun 4, 2007 | 09:37 PM
civicrr's Avatar
pretty sure those were fabbed up by the car builder - roger foo
Old Jun 5, 2007 | 04:18 PM
TPB's Avatar
TPB
Default Re: Remote reservoir shock installation (civicrr)
D'oh... that's what I was afraid of. Oh well, I know where to get commercially available mounts of a different design
Old Jun 6, 2007 | 07:44 AM
david@didrace.com's Avatar
Old Jun 6, 2007 | 08:46 AM
MSchu's Avatar
My Name is Nobody
Default Re: Remote reservoir shock installation (david@didrace.com)
cut a 7" hole and feed them through length wise
j/k
steeltoe
Aug 15, 2009 05:59 PM
Savegascivic!
Paint and Body
Jul 24, 2009 12:20 AM
SoCal EJ1
19
Jun 22, 2008 09:51 PM
See Are X
Mar 4, 2006 10:03 PM
-Whitey-
Sep 23, 2002 07:02 PM
