Running Rich
Old Dec 17, 2006 | 09:28 AM
jaycrx's Avatar
Default Running Rich
stock d15b vtec on virgin p28 ecu
swapped into an 89 CRX
The engine has a hard time holding a steady idle. Running very rich, and getting a CEL #43. i replaced the dizzy cap, rotor, plug wires, and plugs. turned on the engine and drove it around the block. fouled out the plugs immediately. all four were burnt black. getting white smoke out of the exhaust.
could it be BHG ?
maybe the rings are shot?
Old Dec 17, 2006 | 09:38 AM
Inliner's Avatar
i could be wrong but i think your running the wrong ECU... P28 is the D16 Vtec ecu.. i think you want a P06.
Old Dec 17, 2006 | 11:09 AM
jaycrx's Avatar
Default Re: (Inliner)
yea the p28 is the USDM d16z6 ecu, but i have heard you can run it on the d15b with no prob.
Old Jan 28, 2007 | 01:35 PM
Richard...'s Avatar
Default Re: (jaycrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaycrx &raquo;</TD></TR><TR><TD CLASS="quote">yea the p28 is the USDM d16z6 ecu, but i have heard you can run it on the d15b with no prob.
chip the damn thing problem solved you can put what ever map makes you happy and turn off all those stupid over priced sensors you do not need!
SmaTTeRLegion
Aug 3, 2013 08:42 AM
riceordie
15
Sep 20, 2011 10:19 AM
GERBERBOII
Mar 16, 2010 12:44 PM
javon972
Jul 13, 2008 12:17 PM
obuhmyuh
May 6, 2007 05:33 AM
