rpm gauge and speedometer wont work
Old Dec 16, 2006 | 05:42 PM
tommy.'s Avatar
Default rpm gauge and speedometer wont work
my gauge cluster wont work and the the only thing that works is the instrument light. i switched it out and tried to use a different gauge cluster but i got the same results. my headlights and hazards work but my turn signals dont work. what could be the problem? is it my wiring?
Old Dec 16, 2006 | 05:44 PM
john666's Avatar
Default Re: rpm gauge and speedometer wont work (tommy.)
fuses buddy,, check the fuses under the hood and behind the dash
Old Dec 16, 2006 | 05:51 PM
eg-owns you's Avatar
Default Re: rpm gauge and speedometer wont work (john666)
could be a couple diffrent problems what i would do is check the fuse's under the hood. after you have done that i would check the speed sensor in the trans make sure it's connected right or mabey you have a wire cut open grounding it out to the car but i would start with the fuse first if thats fine check the speed sensor
Old Dec 18, 2006 | 07:27 PM
tommy.'s Avatar
thanks
Tank_EM2
Honda Civic (2001 - 2005)
Nov 6, 2015 04:17 PM
PacManSol
Apr 23, 2012 09:29 AM
wwcrxww
Feb 13, 2012 03:17 PM
WT-EF
Sep 18, 2009 08:50 AM
luder916
Dec 17, 2008 07:57 PM
