rpm gauge and speedometer wont work
my gauge cluster wont work and the the only thing that works is the instrument light. i switched it out and tried to use a different gauge cluster but i got the same results. my headlights and hazards work but my turn signals dont work. what could be the problem? is it my wiring?
Re: rpm gauge and speedometer wont work (john666)
could be a couple diffrent problems what i would do is check the fuse's under the hood. after you have done that i would check the speed sensor in the trans make sure it's connected right or mabey you have a wire cut open grounding it out to the car but i would start with the fuse first if thats fine check the speed sensor
luder916
12-17-2008 07:57 PM
