rebuild price of b16?
sup guys, i got a b16a2 from my 00 si
not sure if this is an appropriate question for this forum but ..
i was considering either doing a rebuild or swap
i'd like to know a ballpark price range for a rebuild to stock specs
does anyone have any experience or knowlege about this?
if its cheaper, im considering swapping another b16
any opinons or ideas is appreciated
well why are you swaping the motor? B16's are relatively cheap whats your price range you might get a better build stronger motor if you were to build the b16 for a lil boost.
According to Omniman's DVD, you should use GSR bearings when you rebuild the B16. Just need to get your rods re-tanged. If you rebuild it yourself, let us know how it went!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_vtec »</TD></TR><TR><TD CLASS="quote">I don't mean to hijack, but I'm also thinking about rebuilding a spare B16A for ~20psi, Can anyone recommend a good tutorial that documents the process specifically?</TD></TR></TABLE>
check the forced induction forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun »</TD></TR><TR><TD CLASS="quote">and what do you mean by "rebuild"? i've heard people say they rebuild an engine and all they did was redo the heads and put on a new timing belt.
lol, rods pistons bearings pumps gaskets valve job
Prices vary greatly and you get what you pay for.
was quoted $1200 for complete rebuild fully re-assembled, new pistons.... gotta wonder what the hell kinda parts they use...
Quoted $700 for: (lower end only) tank, hone, bearings, level deck, rings, crank polish, re-assemble... oem parts... more if bore and pistons is needed.
$250 for valve job w/4 valves replaced
is this a difficult job to do on ur own?
thing is, this is my daily, so i dont want a lot of down time
would a swap be much quicker?
my budget is around 2-3 thousand, hopefully closer to two, and preferable w/ a tranny
is there any sites that offer usdm 99-00 b16s?
most sites i went to offer jdm b16s from 92-95 sirIIs or b16As from older generations ...
if i swap, i'd rather purchase from a reputable source than some random guy ..
and if i could do the rebuild myself, maybe rebuild my existing motor as a side project ..
btw, thanks for all the info so far
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killaj12 »</TD></TR><TR><TD CLASS="quote">is this a difficult job to do on ur own?
yes and no...
-if you use common sense and patience it will be a breeze but, when in doubt make sure you check in here with h-t community...and what are you gonna buy stroker kit? or jus pistons and valves etc.
</TD></TR></TABLE>yes and no...
StingRay4
Feb 14, 2007 09:00 PM
