i have a major problem
Old Dec 16, 2006 | 01:46 PM
streetcartuner's Avatar
Default i have a major problem
their is something majorly wrong because this is the 2 head gasket in 3 months can someone help please
stock d15 if that helps
and buns alot of oil is that the rings for sur
Old Dec 16, 2006 | 02:26 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: i have a major problem (streetcartuner)
burning oil could be a resault of a few things ....did YOU change the last HG?
Old Dec 16, 2006 | 03:40 PM
tEKnics's Avatar
Default Re: i have a major problem (Throwdown)
Oil consumption depends primarily on two things: the valve guides and piston rings. If the valve guides are worn, or if there's too much clearance between the valve stems and guides, or if the valve guide seals are worn, cracked, missing, broken or improperly installed, the engine will suck oil down the guides and into the cylinders. The engine may still have good compression, but will use a lot of oil.
Link for you bro http://www.aa1car.com/library/oil_consumption.htm
Old Dec 16, 2006 | 04:47 PM
Throwdown's Avatar
Default Re: i have a major problem (tEKnics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tEKnics &raquo;</TD></TR><TR><TD CLASS="quote">Oil consumption depends primarily on two things: the valve guides and piston rings. If the valve guides are worn, or if there's too much clearance between the valve stems and guides, or if the valve guide seals are worn, cracked, missing, broken or improperly installed, the engine will suck oil down the guides and into the cylinders. The engine may still have good compression, but will use a lot of oil.
Link for you bro http://www.aa1car.com/library/oil_consumption.htm</TD></TR></TABLE>only those 2? what about valve seals?
Old Dec 16, 2006 | 04:49 PM
chrisw85's Avatar
valve guide seals/valve seals, its almost universal terminology.
improper PCV can cause excess oil consumption.
Old Dec 16, 2006 | 04:51 PM
Throwdown's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">valve guide seals/valve seals, its almost universal terminology.
improper PCV can cause excess oil consumption.</TD></TR></TABLE> agreed thats why i said a few things
Old Dec 17, 2006 | 12:25 PM
bluebeast's Avatar
why have u replaced the head gaskets? is it to fix the oil consumption or another reason?
Old Dec 18, 2006 | 06:27 PM
Default Re: i have a major problem (bluebeast)
to fix the antifreze problem the first time,
i think the heads woorpt
but ya thanx guys it really helps
damn_import_culture
Feb 27, 2010 08:38 PM
JDM B16A
Jul 25, 2006 07:57 PM
Takumi Fujiwara
Jan 31, 2006 07:52 AM
RTW DC2R
Mar 19, 2004 09:05 AM
Excelerate
Sep 21, 2003 09:26 PM
