92 civic idle problems!!!! help!
Old Dec 16, 2006 | 12:11 PM
JDMguyss's Avatar
Default 92 civic idle problems!!!! help!
Hello. I have a 1992 Civic with a b18b swap. The idle acts really weird, when i start it up it bounce back and forth from 1200-1500 until it warms up, then itll sit a like 950, like theres no problem. Ive changed the IACV and FITV, is there something im doing wrong or anything I can do to correct the problem?? Thanks!
Old Dec 16, 2006 | 02:29 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: 92 civic idle problems!!!! help! (JDMguyss)
have you clean the TB? also did you buy a used iacv?
Old Dec 16, 2006 | 08:23 PM
JDMguyss's Avatar
Default Re: 92 civic idle problems!!!! help! (Throwdown)
yes, i cleaned the throttle body very well and the IACV and FITV are brand new!
Old Dec 16, 2006 | 09:02 PM
stwano's Avatar
check the valve at the bottom of the hose that goes from the manifold to under the manifold. I couldnt find the problem when my car idled stupid. and it turned out whatever was inside that plastic valve came out.
Old Dec 17, 2006 | 07:24 AM
JDMguyss's Avatar
Default Re: 92 civic idle problems!!!! help! (stwano)
huh??? can you be more specific?? maybe a picture??
Old Dec 17, 2006 | 03:45 PM
JDMguyss's Avatar
anyone else have any ideas?????
Old Dec 27, 2006 | 08:31 PM
JDMguyss's Avatar
what exactly are you speaking of???
Old Dec 27, 2006 | 10:11 PM
smokerz212's Avatar
i have same problem too... my idle plays in 700-900 and it feels like the engine will die... then after a while it will go up to 1500 steady and back to 900 when warmed up... pls help us out. will this cause big problem in the future?
Old Dec 28, 2006 | 06:46 AM
JDMguyss's Avatar
Default Re: 92 civic idle problems!!!! help! (smokerz212)
I know mine does almost the same thing, its getting annoying. Does anyone know anything???
Old Dec 28, 2006 | 07:44 AM
djsire's Avatar
Coolant bubble?
Old Dec 28, 2006 | 11:35 AM
smokerz212's Avatar
more help?!
Old Jan 9, 2007 | 06:55 PM
smokerz212's Avatar
i reset the ecu then solved my problem.
Old Jan 9, 2007 | 07:01 PM
gezzuzz's Avatar
check vacuum hose.. up and down idle means vacuum leak
Old Jan 9, 2007 | 07:31 PM
hard charging 929's Avatar
Default Re: (gezzuzz)
Idle surge, so much fun.
You said it will settle down to 950 or so; this same problem I had on mine for a while. Thought it was the same things that have been mentioned previously.
Ended up being my base idle was set too high. There should be a flat-head idle adjuster screw in the throttle body. Try adjusting your idle lower, cause stock idle for most d series engines(if i'm not mistaken) is 750 +/- 50rpms.
May sound like a small adjustment but it may just solve your problem.
If not get some carb cleaner and turn the engine on; then spray around the IM, IACV and TB; the carb cleaner will temporarily seal the leaking gasket which will help pinpoint a vacuum leak. Find a leak, replace the gasket w/ new.
The air pocket thing. Just ttake the radiator cap off, start the vehicle and put the blower on high and hot. Let it sit for 20 minutes idling, should push most/if not all air out of system. Top off and seal.
Hope it helps out meng.
P.S- What ECU are you running?
93-eghatch
Sep 26, 2009 11:57 AM
snake_eyes
12
Sep 11, 2009 01:40 PM
sonson6
Feb 22, 2008 12:48 AM
mikeunreal
12
Oct 25, 2005 08:14 AM
R. Mack
Jun 1, 2005 07:55 PM
