auto throttle cable on a GSR
ok ive read a couple searches and they all say the same thing, i guess i wont need a new throttle cable if i just swap out the gas pedal to the new manual pedal assembly but i just wanted to make sure that it would hook right up to a GSR throttle? or do i need to modify the cable or possibly buy a new one?
If you putting a GSR throttle body.. You'll need the GSR throttle body cable...
But you only changing the pedals then don't need to change the cable.
Basically use the throttle body cable that match your throttle body
92EG8
Jul 4, 2009 10:22 AM
