GSR Trans problem.
Old Dec 15, 2006 | 09:46 PM
pcupo12's Avatar
Default GSR Trans problem.
Just had a JDM Gsr swapped into my EG. It used to be an auto D, now its a 5 speed B18C. The other night I was driving home and stopped at a light.....went into first no problem, wouldnt go into second and the clutch pedal felt a little weird. I stopped in a parking lot nearby. The car will NOT go into gear when the engine is running.....I turn the motor off, step on the clutch and it will go into any gear I want, just not when the car is running. What do you guys think is up? Its a brand new exedy stage 1 with a resurfaced OEM Flywheel. I had it done at a shop and im bringin the car back on monday, but Im just curious on what this could be.....anyone?
Old Dec 15, 2006 | 10:22 PM
turbod da's Avatar
Default Re: GSR Trans problem. (pcupo12)
check fluid ..........and also the slave cylinder ..
Old Dec 15, 2006 | 10:57 PM
'94civic b16's Avatar
Default Re: GSR Trans problem. (SNACH)
ill second the fluid check. Look for a leak or even just try bleeding the system.
Old Dec 16, 2006 | 08:54 AM
pcupo12's Avatar
There is plenty of fluid.....what is bleeding the system going to do? I could swear the clutch pedal felt weird on that one shift, almost like something let loose.....Ill be towin the car to the shop but its going to cost me $40 for the trailer and even more for diesel fuel for my truck being the shop is an hour away.
mheathers1
Mar 8, 2014 12:42 PM
sipolt89
Transmission & Drivetrain
Dec 10, 2008 04:13 PM
Blk00EJ8
28
Jul 27, 2007 04:03 AM
vti444
Jun 13, 2005 03:44 PM
abeaujuin
Dec 30, 2003 04:48 PM
