car's blow off valve sounds different all of a sudden
Old Dec 15, 2006 | 01:04 PM
lv6l's Avatar
Default car's blow off valve sounds different all of a sudden
94 honda civic cx
jdm d16a sohc vtec
t3/t4 turbo w/ front mount intercooler
universal blow off valve
rc550 cc injectors
external wastegate running at 5lb spring
basemap chip tune
here's my problem. i was driving home from a friend's house one night and everything works fine, but when i got home and left again about 3 hours afterwards my blow off valve sounds funny now. before it would have the quick *psh* noise. now it has the noise but softer and a lot longer. so now it would sound quiet and *psssssssshhhhhhhh.......* i check all my couplings for leaks and vacuum lines; they all look fine. so i dont know whats seem to be the problem so here i am on honda tech. any inputs would be great. thanks.
Old Dec 15, 2006 | 01:12 PM
not2slo128's Avatar
Default Re: car's blow off valve sounds different all of a sudden (lv6l)
check turbo for shaft play.
is the boost level the same as before?
Old Dec 15, 2006 | 02:35 PM
lv6l's Avatar
shaft play is the turbo moving in and out right? or up and down?
Old Dec 15, 2006 | 11:24 PM
LsCivic18's Avatar
It Shouldnt Move Up Down Or In And Out
Old Dec 16, 2006 | 01:34 PM
lv6l's Avatar
its not moving in or out. but up and down very very very little. hardly noticable. i believe this should be normal.
Old Dec 16, 2006 | 08:45 PM
97spooncivic's Avatar
Default Re: (lv6l)
when you say universal bov, what style is it. Since you says pshhh noise and not a whistling sound, it is a mimic of the XS RFL? If so, you may need to put some oil or grease because it gets stuck.
Old Dec 16, 2006 | 10:09 PM
HamiltonRex's Avatar
Default Re: (LsCivic18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsCivic18 &raquo;</TD></TR><TR><TD CLASS="quote">It Shouldnt Move In And Out</TD></TR></TABLE>
my brand new garrett did.. not much only a few thous. Needs room for oil
Old Dec 17, 2006 | 01:51 AM
HiProfile's Avatar
Default Re: (HamiltonRex)
Why would you take a BOV sound change and assume the turbo is crapping out? As long as he's at the same psi as before when closing the throttle, it shouldn't vary the sound. My guess is that the diaphram/o-ring that seals the vacuum port is shot. If its leaking there, the bov will move very slowly.
Old Dec 17, 2006 | 02:52 PM
lv6l's Avatar
i'll check the bov and grease if needed and see if that fix the problem.
Old Dec 17, 2006 | 03:39 PM
Flashmn's Avatar
Default Re: (lv6l)
side to side play is acceptable to a point. In-out isnt at all.
Old Dec 18, 2006 | 08:17 PM
lv6l's Avatar
i think i fix the problem. end up having a hairline crack on my vacumm hose and it effect my bov. iono why my gauge didn't change but i think it works now. so far so good. thanks a lot for all the inputs.
doezitmater
Aug 23, 2006 11:52 AM
buddha1320
Jul 20, 2005 09:03 AM
Typiko512
Sep 22, 2002 04:24 PM
Aahj
Jan 14, 2002 05:51 PM
