Wire tuck gone bad.... need advice
Old Dec 15, 2006 | 07:23 AM
atxsir's Avatar
Default Wire tuck gone bad.... need advice
hey guys i was doing a wire tuck on my 98 civic hatch w/k series and after i finished everything i have some problems. I have checked over and over again. Grounds, connections, any splices, and made sure all the wires are connected correctly.
1) when i turn on accessory or hid it disables the rpm gauge.
2) my car doesnt hold any charge when i remove the positive when the car is running it turns off. after 10 minutes when i start the car with a jump box it will die by itself.
could the alternator have taken a **** while i was doing the tuck? seems impossible but i just need some suggestions if any. thanks.
Old Dec 15, 2006 | 12:19 PM
sexyrex's Avatar
whats a wire tuck?
when disconnecting the battery, you're suppose to remove the negative first, and than positive, its also not wise to disconnect the battery while the car is running, your battery takes in voltage spikes.
Old Dec 15, 2006 | 12:36 PM
h22__guy's Avatar
Default Re: (sexyrex)
a wire tuck is when you lengthen the wire harness and rerout it through fenderwells ect... you have to cut lengthen and solder the whole harness. makes the engine bay way cleaner. you can also remount yout fuse box under the dash or elsewhere... so if a mistake was made its hard to trace. i always learned solder connect but dont eevr wrapp and tape the wires until you confirm that everything is properly working that way if you have to source the problem you dont have to unwrap your wire loom, tape, zip ties ect.... did you solder everything and check all your grounds? one wire at a time and makes best if you can use a color system.
Old Dec 15, 2006 | 03:08 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
did you move your rpm ground? change ground locations on every ground that you messed with that may be related to the circuits that are screwing up.
i have a feeling that this is a ground problem somewhere.
Old Dec 15, 2006 | 09:19 PM
atxsir's Avatar
Default Re: (full Circling)
thanks guys, it WAS a bad ground for the alternator. thanks for the advice!
Old Dec 16, 2006 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling &raquo;</TD></TR><TR><TD CLASS="quote">did you move your rpm ground? change ground locations on every ground that you messed with that may be related to the circuits that are screwing up.
i have a feeling that this is a ground problem somewhere.</TD></TR></TABLE>
dude you ******* rule so hard!
Old Dec 17, 2006 | 02:45 PM
h22__guy's Avatar
i said check all your ground too j/k lol glad you found your problem now post pics!!!
tangerinebeast
Jan 5, 2011 03:48 PM
civics4lyfe
Jan 28, 2009 08:52 AM
EG6 PSI
Dec 31, 2008 01:27 PM
Mr. Giggles
Oct 31, 2006 12:20 PM
elmalouno
Aug 10, 2004 02:44 PM
