NEED HELP NOW!~!! FACTORY B16 transmission fluid change HELP~~
I know I can fill the transmission up by taking the speed sensor out but is there anyplace I need to put fluid in for the lsd?.... Putting the motor back in my car now and would like to know withing the hour!!!
no just fill up the tranny. why are you filling it up through the speed sensor? why dont you just fill it up through the plug, if you look at the tranny drain plug its right above it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOBIG_CTR »</TD></TR><TR><TD CLASS="quote">no just fill up the tranny. why are you filling it up through the speed sensor? why dont you just fill it up through the plug, if you look at the tranny drain plug its right above it.</TD></TR></TABLE>
Well, filling it through the speed sensor hole is easier since it's right there, but I still do it through the actual fill hole. It's not that hard at all, you just need a long funnel with a curved end or a short funnel with a hose attached to the end, and then you always know it's filled to the right level instead of measuring it
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
