gsr rear sway bar on 96-00 civic. need aftermarket lca?
I have this sway bar sitting in my garage for the past year now. and i want to bolt this up.
Is the Endlinks the only problem?? i plan on buying blox endlinks or some oem civic si's
and also this will bolt up to my stock lca right?
I believe this is a 14mm swaybar. THis wont tear my rear subframe that i hear from itrs. I do plan on getting asr/price but looks nice or a beaks kit eventualy wiht itr sways.
thanks any info would happily appreciated
i just went through what your going to. NO you will not need different LCA's, with the em1/blox/cr-v endlinks it should bolt up. However make sure you have the addpater plates/brakets that bolt on to your rear subframe, As the D brackets that go over the bushings will not dirrectly bolt up to the rear subframe without those brackets. Also if your gona go with the ITR later on definetly go for the ASR or Competch braces, as i have read some sketchy *** shiat about the beaks. Oh and you will have no problmes runnning the 14mm without a brace.
Just read the post above. thanks man, very very informative and helpful. this is wats this community is all about.
I am in the process of putting a front swaybar on. just found out that you can use Teg's front lca, but need civic si's forks and watever front swaybar you please
straight, ima check out tomorrow if i have all the parts including the adapter plates
That part in the middle is the D-brackets right? and not the adapter plate?
that pic right there is stolen from ebay that looks exactly like mine but i would need compatable endlinks and adapter plates? right
If not where can i find an adapter plate?
ok, the one in the pic has everything you need. The brackets im talking about are on there. I went through hell and back cause i didnt know this **** so no problems man.
http://www.slhondaparts.com/br...=true
the brackets are part 30.
https://honda-tech.com/zerothread?id=1799825
and here is one of the threads i made
I have an ex front 22mm swaybar setup for sale if you are interested. Comes with everything you need including endlinks and lca's.
spyz34
Jan 29, 2005 10:37 PM
mixmastabob
Jan 6, 2004 09:51 PM
