itr cams or something bigger?
Old Dec 14, 2006 | 06:39 PM
ecksman's Avatar
Default itr cams or something bigger?
im currently in the process of putting together a simple lsvtec. friend of mine sold me dual valves springs, retainers, new oem valves, and itr cams for $450. been thinking of selling them and putting the $ towards something bigger. would i get the full benefit of having bigger cams on a stock ls block?
Old Dec 14, 2006 | 06:43 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: itr cams or something bigger? (ecksman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">im currently in the process of putting together a simple lsvtec. friend of mine sold me dual valves springs, retainers, new oem valves, and itr cams for $450. been thinking of selling them and putting the $ towards something bigger. would i get the full benefit of having bigger cams on a stock ls block?</TD></TR></TABLE>
What pistons and rods are you using?
What is the motor for exactly?
Old Dec 14, 2006 | 06:45 PM
ecksman's Avatar
Default Re: itr cams or something bigger? (Capt. Blonde Beard)
for the meantime its just stock b18b, out of my 94 ls, with a b16 head, dc 4-2-1 headers, no name intake, chipped p28. thats it for now.
Old Dec 14, 2006 | 06:55 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">for the meantime its just stock b18b, out of my 94 ls, with a b16 head, dc 4-2-1 headers, no name intake, chipped p28. thats it for now. </TD></TR></TABLE>
So nothing in the bottom end even rod bolts ?
Old Dec 14, 2006 | 06:57 PM
ecksman's Avatar
nope
Old Dec 14, 2006 | 07:02 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">nope</TD></TR></TABLE>
I would do that before even worrying about cams.
What good is a motor with a tossed rod
Old Dec 14, 2006 | 08:34 PM
ecksman's Avatar
ive seen heads thrown ls' with a good amount of miles on them and they seem to run pretty good.
Old Dec 15, 2006 | 09:10 AM
twotonecivic's Avatar
ls blocks are pretty sturdy from the factory. imo until you start puttin boost upon boost then stock block is good to put down some h.p., i don't see any reason y the itr cams would give you any problems.
Old Dec 15, 2006 | 10:11 AM
Ass$nyper's Avatar
Default Re: itr cams or something bigger? (twotonecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">ive seen heads thrown ls' with a good amount of miles on them and they seem to run pretty good.</TD></TR></TABLE>
You arn't using an LS head so what are you talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twotonecivic &raquo;</TD></TR><TR><TD CLASS="quote">ls blocks are pretty sturdy from the factory. imo until you start puttin boost upon boost then stock block is good to put down some h.p., i don't see any reason y the itr cams would give you any problems. </TD></TR></TABLE>
To best use ITR cams you'll be revving pretty high, and heck even the 8200 rpm stock for a b16 is too much for a lsvtec with out any bottom end work.
Revs kills motors, I know its a huge simlpefaction but LS motors arn't made to spin that high, sure they are stout but they rather see 50HP more then 500 revs more. Rods and the bolts being the weakest link.
What I would do is spend that money getting the rods shotpeened and polished and ARP rod bolts.
Old Dec 15, 2006 | 10:18 AM
black_EM1's Avatar
Community Builder
Community Influencer
ARP rod bolts at the least. Stock LS rod bolts start to stretch ~ 6000-6500 rpm
And while you're in there, get the crank balanced and micropolished.
S
Old Dec 15, 2006 | 10:21 AM
Ass$nyper's Avatar
Default Re: itr cams or something bigger? (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">ARP rod bolts at the least. Stock LS rod bolts start to stretch ~ 6000-6500 rpm
S</TD></TR></TABLE>
Thank you Charles, now someone who knows what they are talking about backs maybe they will listen before the grenade that is there rods goes off because taching them to 8K sure pulls the pin
Off hand and semi on topic, isnt the crank good for quite a bit more? I turn my stock LS crank to 8500.
Old Dec 15, 2006 | 10:33 AM
black_EM1's Avatar
Community Builder
As far as I know, the crank is good to 8-something. All B-series cranks are balanced to some extent, there's just differences between how high the revs.
Or so I've been taught. I've seen LS cranks spin to 9,000+.
Old Dec 15, 2006 | 10:34 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know, the crank is good to 8-something. All B-series cranks are balanced to some extent, there's just differences between how high the revs.
Or so I've been taught. I've seen LS cranks spin to 9,000+.</TD></TR></TABLE>
Ok cool that's what I thought, thanks again.
my head still rattles, I'll adress that first
Old Dec 15, 2006 | 11:10 AM
ecksman's Avatar
Quote, originally posted by ecksman »
i meant that people around here have just thrown on vtec heads on their ls blocks (used, never rebuilt, some with a lot of miles on them) and had success.
my question is should stick with itr cams or would skunk2 pro 2 be too big of a cam for me with a stock block
Old Dec 15, 2006 | 11:18 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by ecksman »
my question is should stick with itr cams or would skunk2 pro 2 be too big of a cam for me with a stock block</TD></TR></TABLE>
They are foolish and lucky on borrowd time, it's that simple.
if you really must do it your way ITRs would behave alot better then s2 pro2 on that motor.
Old Dec 15, 2006 | 11:24 AM
ecksman's Avatar
when u say behave u mean idle or it would a broader power curve
Old Dec 15, 2006 | 11:34 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecksman &raquo;</TD></TR><TR><TD CLASS="quote">when u say behave u mean idle or it would a broader power curve</TD></TR></TABLE>
As nicely as I can say this search.
Skunk2 pro2s are big cams that want alot of comp and need to rev, ITRs are a stock part thats pretty badass for what they are but still a stock part made for a stock street car.
Old Dec 15, 2006 | 12:04 PM
ecksman's Avatar
how do i search?
just kidding, thanks for the info. just wanted to make sure before i got rid of the itr cams
zex_cool
Apr 6, 2011 03:36 PM
killerB16A
Oct 13, 2009 10:08 AM
rdeezy78
Mar 12, 2007 03:38 PM
geces23
Aug 8, 2006 05:00 PM
hondatuner20
Jun 7, 2005 01:52 PM
