compression
Why is it said the lower the compression the better for FI cars? I'm building a gsr block with ls internals and I'm coming up to the piston purchase. I hear different things like the lower the better. I want to go with 9.0-1 and a friend of mine is runnign 10.0-1 on his ride. Is there a hp difference in the ratios?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snaileg »</TD></TR><TR><TD CLASS="quote">high comp gets more hp but unsafe and lower comp is safe like a 9:1 compared to a 10:1 isnt a huge difference just about 10whp </TD></TR></TABLE>
posts like these make people dumber. I award you no points and may god have mercy on your soul
Here is a brief advantage/disadvantage list of purely low compression vs. high compression. Don't let this be the end all, do your own research and figure out for yourself.
<FONT SIZE="2"><U>Low compression:</U></FONT>
Advantage:
Lesser forms of fuel can be used (Ie: a little higher numbers on pump gas)
more tuning error is allowed
Disadvantages:
Creates less power in the whole RPM range(about 3 to 7% for a full point of increase)
<FONT SIZE="2"><U>High compression:</U></FONT>
The opposite of low compression
Don't be scared about the tuning part. Even people with 11.0:1 and higher have turbo cars. It just needs a good tune to it that is precise and the fuel in the tank is proper for the power output. It's that simple.
Advantage:
Disadvantages:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snaileg »</TD></TR><TR><TD CLASS="quote">im sorry im car stupid today =\ </TD></TR></TABLE>
You weren't wrong, just way too overgeneralized and then some n00b thinks this is absolute truth and nothing else matters......and there lies the problem
