Ls Vtec compression ratio limit on 93 pump
Old Dec 14, 2006 | 01:32 PM
DC_Legacy's Avatar
Default Ls Vtec compression ratio limit on 93 pump
This will be my first Honda build among my previously owned vehicles. Money is my biggest factor, so I dont have the money for a GSR block with forged internals and turbo. I,m gonna keep it cheap but workable with an LS-Vtec B16a2 head and CTR pistons. I,ve looked at a lot of data online, and figured that the estimated compression ratio would be close to 12:1 since these pistons make 10.4:1 in th B16. Is this right? and if so, can I do this on 93 without detonation problems? If its gonna be a problem I'll probably just add another half a layer of gasket to bring it down, but if I can get away with it than I'll stay a 12:1.
Old Dec 14, 2006 | 01:37 PM
Padawan's Avatar
Darth ModerVader
Default Re: Ls Vtec compression ratio limit on 93 pump (djlogiq06)
Are you installing this in a Type-R?
Old Dec 14, 2006 | 01:39 PM
DC_Legacy's Avatar
Default Re: Ls Vtec compression ratio limit on 93 pump (Padawan)
no actually , no its an ls but I relized that I submitted the question on the wrong forum.
my bad.
Old Dec 14, 2006 | 02:30 PM
itr1244's Avatar
this is ITR forum . not LS/vtec forum
try somewhere else
peace
Old Dec 15, 2006 | 08:10 PM
itr1137's Avatar
Default Re: Ls Vtec compression ratio limit on 93 pump (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">this is ITR forum . not LS/vtec forum
try somewhere else
peace</TD></TR></TABLE>
you are such an a-hole. leave your negative comments to yourself.
Old Dec 15, 2006 | 08:17 PM
RiceNBeans's Avatar
Default Re: Ls Vtec compression ratio limit on 93 pump (itr1137)
Sorry but you are in the wrong here. This is an ITR forum. Quit blaming the man for wanting to keep this area on topic.
Old Dec 15, 2006 | 09:38 PM
itr1244's Avatar
Default Re: Ls Vtec compression ratio limit on 93 pump (RiceNBeans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceNBeans &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but you are in the wrong here. This is an ITR forum. Quit blaming the man for wanting to keep this area on topic.</TD></TR></TABLE>
that's right beetch
Old Dec 15, 2006 | 09:49 PM
neo_'s Avatar
You have two factors in compression ratios. Dynamic and Static. People have run 13:1 on very big cams before such as Buddy Club Spec 5+ and have been able to run it on 93 pump with a good tune. One thing to remember, on high compression you generally will need to retard the timing so your engine does not ping.
I personally run a 12.5:1 compression ratio and it runs perfect on 93 octane with the timing being 16.5. I've been runing this CR for almost 3 years with no major problems (knocks on wood). It's all about the tune, don't cheap out on it.
Old Dec 15, 2006 | 10:04 PM
LoserKid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djlogiq06 &raquo;</TD></TR><TR><TD CLASS="quote">no actually , no its an ls but I relized that I submitted the question on the wrong forum.
my bad.</TD></TR></TABLE>
HURRY EVERYONE BASH HIM....o wait look what he posted 3rd in the thread.... H-T "watch out the people that got made fun of in high school will get you right quick on H-T"
olskoolhatchy
May 7, 2008 12:56 AM
million
37
Jan 6, 2007 12:00 AM
DC_Legacy
Dec 14, 2006 02:42 PM
93turbotegSAV
Nov 20, 2006 11:58 AM
iseecivic
Feb 12, 2006 08:00 AM
